2018+ Softail Models Breakout
abs or not
Old May 13, 2019 | 06:13 AM
Campy Roadie's Avatar
Campy Roadie
Start here @ post #38
https://www.hdforums.com/forum/touri...ake-fluid.html
then here
https://www.hdforums.com/forum/frame...at-dealer.html
The long story short is Harley designed an ABS braking system that when a part of it fails it results a complete loss of all braking, on that circuit (front or rear). No other motorcycle company in history has designed and put such a system in place. It was made in China by BWI. Bottom line, I flushed my braking system(s) once every 12 months (HD recommends every 24 months) and I went in for a recall flush. Their computer fragged my ABS ECU and all I got from HD was "oh well, it's out of warranty, the dealer can fix it for a little over a grand".
Again, I'm not talking about Non-ABS vs ABS, I'm talking about ABS from a company that has done what no other company ever has, which is sell a system that fails and causes the complete loss of braking capability. All the "mine works fine, it's not a real problem" isn't worth anything if it happens to you. As far as I'm concerned, the way HD is handling things right now, the less technology you buy in a new HD the better.
That's my first hand experience.
Old May 13, 2019 | 06:29 AM
MoneyFor's Avatar
MoneyFor
We have no choice, ABS is standard on all the Harley's overhere.
Old May 13, 2019 | 08:36 AM
Tozco's Avatar
Tozco
I went out of my way to get a non ABS Low Rider because I prefer the simplicity and reliability and no need for dealer bleeding of ABS module. I've owned three bikes with ABS and for me it's more about the particular set up than whether or not it is ABS equipped. Everyone here who states that ABS saved their lives, were you panic stopping on sand or oil soaked roads or something?
Old May 13, 2019 | 08:55 AM
MoneyFor's Avatar
MoneyFor
I bleed all of my ABS systems myself on the Harley's with a regular vacuum system on a compressor, U can bleed as a regular system if leave the contact off and you keep an eye on both
front and rear master cylinder. Also I have a Motoscan 6050 that have the bleeding function on it but as said, not needed for Harley I use it only for my GL1800.
Old May 13, 2019 | 09:22 AM
Tozco's Avatar
Tozco
That's good to know.
Old May 13, 2019 | 09:33 AM
FLS103's Avatar
FLS103
I was riding home from work, freak summer rain showers, wet roads. A lady pulled straight out in front of me and put left signal on to turn, I braked hard, split second reaction and I didn't get good hold on lever, my hand slid off front lever but I was still hard on rear. System pulsed until I could get a hold on front lever again. Not saying it saved my life but probably prevented the rear from coming around. On older bikes I would let off the rear brake if rear came around, you probably know the routine. The abs bought me a few feet of stopping distance because I stayed on the rear brake, I stopped with feet to spare. Might not have saved my life but it was nice to have ABS that day.
Old May 13, 2019 | 08:04 PM
cj24's Avatar
cj24
then here
Geeze that sucks...
Thanks for posting. I wonder what percentage of folks are having issue with ABS?
Old May 13, 2019 | 08:07 PM
Campy Roadie
Originally Posted by cj24
Geeze that sucks...
Beats me, but at my house the ABS failure rate is 100%.
Old May 13, 2019 | 08:09 PM
cj24's Avatar
cj24
Yea i got that... definitely see where you are coming from on that due to your experience
Old May 14, 2019 | 04:42 AM
OldMike's Avatar
OldMike
Regarding the new softails abs or not? I have seen the reports on problems and the recall. But with the new softails and low rider... issue worked out? My current bike does not have abs and if Harley has them working well would definitely consider them.
I skipped it because of cost and maintenance. Had ABS on my 2014 Street Glide but it also used linked brakes so I don't know if it's the same ABS system.
