Is this possible?
You better have a good parts guy or tech to talk to about this and not just some monkey that never worked on anything in his life until he went to MMI. The guy who went to school won't have a clue, he will look it up and see a different part # not knowing the different # pertains to neck angle and coating. The guy who is a gearhead and has been there and done that will give you the proper answer.
47000127FRAME, with 48315-60, 66055-93 (gloss black)FXBR, FXBRS, FXBRS ANX
47000128FRAME, with 48315-60, 66055-93 (denim black)FXFB, FXFBS
47000129FRAME, with 48315-60, 66055-93 (gloss black)FLFB, FLFBS, FLFBS ANV, FLFBS ANX
Someone else can work this out, no FXDR or FLSB though.
Peace .
47200460FRAME CROSSMEMBER, upper, rearFLDE, FLHC, FLHCS, FLHCS ANV, FLSB, FLSL, FXBB, FXFB, FXFBS, FXLR
47200461FRAME CROSSMEMBER, upper, rearFLFB, FLFBS, FLFBS ANV, FLFBS ANX, FXBR, FXBRS, FXBRS ANX
Still no FXDR or FLSB though.
Peace.
width as the Slim. I think it's going to be a weird sight if you install the Fat Bob fender and struts on the Slim. What I did on the Street Bob is a 4,5" rim with a 170 tire on it, that is the max you will get in the oem fender.
If you want to go wider then you better go with the fender from Rick's or even better with the one from Thunderbike like I did on my Breakout, it have integrated tail/brakelight and indicators and that gives it a much cleaner
look.
