2018+ Softail Models Breakout
Lowering Heritage
Old Jul 17, 2019 | 06:45 AM
Chunker's Avatar
Chunker
Default Lowering Heritage
Is there a lowering kit for the new Heritage? On my 2013 Fatboy I had the lowering kit installed at purchase which I suppose made it similar to the Fatboy Low. Bottom line I had good ability to flatfoot while sitting. Fast forward to now and my Mustang seat, Wide touring, just came in and my initial perception is the seat brings me up maybe an inch. I could flatfoot the stock seat but want and need a driver's backrest, (bad back). I know there is a preload on the rear shock and I'll have to check where it's set. I suppose the preload is to adjust rebound of the shock depending on planned weights.
Old Jul 17, 2019 | 07:01 AM
Chunker's Avatar
Chunker
I did a search and JP cycles sells the Progressive 465 mono shocks in various lengths and either standard or heavy duty. Some have a remote preload adjuster, some pre-set. It appears that they go from standard height to as much as 2" lower. I put Progressive 940 on my 11 FLHTK and was very happy with them. They were also selected because they lowered the rear 1". I know that lowering any suspension part will limit lean angle and 2" might be an extreme. I'm not a lean it way over type rider and never had significant issues with the touring or Fatboy being lowered other than an occasional footboard light scrape. That does get a passenger's attention.
EDIT; The Progressive 465 come in 4 lengths, from 13.5 to 12.2. 13.1 being stock height. On the surface the 12.2 would seem to be the best for lowering BUT is lowering the rear that amount without lowering the front going to cause odd or unstable riding conditions. The lengths are 13.5, 13.1, 12.6 and 12.2. The note on the Progressive site says each length changes the axle height by 1". My Fatboy was only lowered in the rear using the HD Softail lowering kit and was fine. But a different animal.
Old Jul 17, 2019 | 07:19 AM
MoneyFor's Avatar
MoneyFor
I lowered my FXBB myself with altering and fabricating some parts on the oem shock, it sits 3/'4" lower and that is enough since I'm a lean over guy and allready hit the road now with my V&H big radius.
Old Jul 17, 2019 | 09:43 AM
Tozco's Avatar
Tozco
Harley makes a shorter shock specific to the heritage. You can also swap in a short shock from one of the other Softail models. Only the heritage and the fatbob have the long shock.
Old Jul 17, 2019 | 10:42 AM
Chunker's Avatar
Chunker
Thanks, I looked on the HD site for parts and the only lowering kit was for the 17 and older Softail. I'll check with the dealer to see how much the short one is and install. The Progressive as nice as they are cost $649.
Do you have any experience with the shorter shock or know someone who does? As yet I have very few miles on the Heritage, weather here is uncomfortably hot, but it'll get better I hope.
EDIT, just found the low profile shock in the parts specific to the bike. Lowers 3/4" which would be good and priced at $390. Now I need to find one of those online dealers with 20% off like used to get stuff. Installation says "refer to service manual" so not sure at this time what's involved in putting it on.
Old Jul 17, 2019 | 10:53 AM
Thingfish's Avatar
Thingfish
I put the Harley stock Deluxe shock on my ‘18 Heritage, which is about an inch shorter, just as an experiment mostly for looks. It was around $230. There are zero effects on handling and pretty minimal on lean angle lowering just the rear, but it’s also a pretty small change visually and footing wise. Ride was a tad harsher, but nothing bad.
It is a noticeable height difference, but not sure it would be enough for your needs. If you do the labor yourself (pretty easy in about an hour) it’s also cheap if you have the tools and service manual. If you don’t have that, it’s probably cheaoer to have the dealer do it. You do need to adjust the headlight angle.
Front and rear lowering would likely be more significantly noticeable.
Another cheap option is to have your seat narrowed a bit. This will give you better reach to the ground.
I’m putting the stock shock back on for a 2-up road trip in a few weeks. If I realize I prefer the stocker, I might consider selling the shorter shock if you’re still interested at that time. Has about 6,000 miles of use on it.
Old Jul 17, 2019 | 11:25 AM
Chunker's Avatar
Chunker
Thanks, may take you up on that. I'm still researching options and need to put a few miles on to see what my thoughts are. I plan to get the service manual, just looking for best $$ options. 3/4" would be a good drop especially when I have my boots on. I'm working on the bike wearing thin tenny runners. I took the seat off to put the Mustang on but didn't look much at what was under there. I'll pull it and take a look see. I'm mechanical adept and generally avoid dealerships except when warranty or specialized tools required that I don't have and don't want to add to the collection. As it is I have stuff applicable to bikes I no longer have. If you don't mind, PM me what you want.
Old Jul 17, 2019 | 01:42 PM
Tozco's Avatar
Tozco
Monoshock removal and replacement on the 2018 and up Softail is a very straight forward procedure.
Old Jul 17, 2019 | 03:25 PM
Chunker's Avatar
Chunker
Just removed the seat and looks like one T-50 Torx, one 3/4", one T-27 Torx, one zip tie. Probably less than a 1 beer job. I suspect I'll have to lift the frame but I have a motorcycle lift for that if necessary.
Old Jul 17, 2019 | 03:38 PM
Thingfish's Avatar
Thingfish
Yeah that’s about it. The manual wants you to remove the rear fender which was easy enough, but I’ve seen people post you don’t need to if you have the right extension for your ratchet. Some blue locktite for reassembly. The lift just helps you line up the mounting bolt hole.
