2018+ Softail Models Breakout
Lowering Heritage
Old Aug 16, 2019 | 03:38 PM
BurpleHugger's Avatar
BurpleHugger
Originally Posted by Chunker
Just removed the seat and looks like one T-50 Torx, one 3/4", one T-27 Torx, one zip tie. Probably less than a 1 beer job. I suspect I'll have to lift the frame but I have a motorcycle lift for that if necessary.
So how did this turn out? I'm looking to lower my bike, if I read correctly the Heritage oem shock is 2" lower... do you know if it is a direct swap for the FXBB?
Old Aug 16, 2019 | 05:20 PM
FrankEV's Avatar
FrankEV
Is there a lowering kit for the new Heritage?
H-D Low Profile Front Suspension: https://www.harley-davidson.com/stor...03-45500427--1
H-D Low Profile Rear Suspension: https://www.harley-davidson.com/stor...03-54000134--1
If you do the front make sure you use the heavy oil...makes a lot of difference.
Old Aug 16, 2019 | 06:55 PM
coopmonte's Avatar
coopmonte
If I would have seen this sooner I would have done a straight trade for the Low Rider shock, as I want it a bit taller. Hope everything worked out for you, any update to how it affected the ride/
Old Aug 17, 2019 | 05:02 PM
Tozco's Avatar
Tozco
Nobody said that. The OEM heritage shock is the long one, it will make your bike taller.
hardtimes2
Mar 18, 2018 05:28 AM
Chunker
Nov 8, 2012 07:12 AM
tnhd06
Jan 15, 2009 10:25 PM
BERRYP
Jan 14, 2009 12:03 PM
texfatboy
Sep 22, 2008 11:44 AM
