2018+ Softail Models Breakout
Fxbb 2019
Old Jul 31, 2019 | 09:28 PM
Agoober's Avatar
Agoober
Originally Posted by Birtyyy
Would changing drive sprocket ratios have the same negative effect?
Yes, though you can make it right through a tuner. I believe the EPA tuner may be able to do it and the other tuners should all be able to do it.
These were the ABS codes but may have been changed.
C1021 ABS front WSS always zero
C1023 ABS rear WSS always zero
C1025 ABS Front wheel speed intermittent
C1027 ABS rear wheel speed intermittent
C1029 ABS wheel speed difference too high
C1032 ABS Front wheel speed circuit open/shorted
C1034 ABS rear wheel speed circuit open/shorted
C1040 ABS pump/motor error
C1055 ABS ECU internal error
C1061 ABS front apply solenoid circuit open/high resistance
C1062 ABS front release solenoid circuit open/high resistance
C1065 ABS rear apply solenoid circuit open/high resistance
C1066 ABS rear release solenoid circuit open/high resistance
So if one of these come up you know what you did.
Steve Cole a sponsoring member here will know exactly what will or won't work.
Peace .
Old May 26, 2023 | 10:09 AM
nojo's Avatar
nojo
4th Gear
Default FXDB rear on FXBB
I just picked up a 17" X 4.5" rear off a Dyna Street Bob, from what I've read should be a pretty straight forward swap but I'll soon find out!
Don’t mean to dig up an old post, but did you get that on? I am thinking about taking my hub from the softail and respoking the dyna. But I’d like to bolt up the whole thing if it’s doable.
tnx
Old May 29, 2023 | 07:19 PM
Birtyyy's Avatar
Birtyyy
tnx
Yes I have a dyna 17"x4.5" rim laced to my FXBB hub.
also didn't throw any ABS codes as someone mentioned might happen.
2019 FXBB with 17" x 4.5" rim
obennici@gmail.com
Dec 28, 2012 05:40 PM
p51bombay
Dyna Parts
May 30, 2012 09:08 AM
Taddeoeg
Dyna Models
Jan 22, 2010 10:03 PM
cpsychoholic
Dyna Models
Nov 8, 2008 08:47 PM
bobbsterkid7
Custom Models
Oct 23, 2007 01:33 PM
