2018+ Softail Models Breakout
S&s dB killer screws
Old Aug 7, 2019 | 12:47 AM
  #51
MoneyFor's Avatar
MoneyFor
Looking at the partlist that OldMike posted I'm guessing that both exhaust use the same db killer and bolts.
  #52
Sliceoflife's Avatar
Sliceoflife
Originally Posted by Cardavidson
Molto bravo, Lorenzo!! (and thank Fabio from me, too ..)
So, to sum up, and only to confirm for your side, if it is possible...
1) the wonderful screws are STYKFITŽ7
2) when you say "angrever", you're saying a normal metal drill bit, right?
3) You have removed one of the two screws, so the configuration you are going to try is without the dbkiller but with the baffle
Finally, thank you very much, colleagues .. Mchad, Goldmike, MoneyFor ..... and everyone!!. Thank you very much for your help!
I really appreciate your desire to help.
Best regards from Spain!!
1 yep
2 No, before is mandatory,due to the ‘air’ you have around the screw, to make a mark on the top of the pin in order to avoid the drill bit goes out from that “air” scratching the pipes top; in Italy the name is “ bulinatore” .
3 I removed 6 tamperproof screws (3 per pipe) and the dB killer not yet touched the ones on the side because not needed.
Old Aug 7, 2019 | 12:53 AM
  #53
Sliceoflife
Originally Posted by MoneyFor
Lorenzo what size are the 3 bolts , length, diameter and thread ( thread : mm's or inches ) please ?
Inox 4 mm diameter ,20 mm length thread in mm
I was warried about the thread because in Genoa where I leave is not so easy found out inches thread screws. Surprised about that
Old Aug 7, 2019 | 12:55 AM
  #54
MoneyFor's Avatar
MoneyFor
I think that n°2 , we call it a "puntslag" or point stroke , not sure what the correct English is for this but it keeps the drillbit in center while drilling.
Old Aug 7, 2019 | 12:57 AM
  #55
MoneyFor's Avatar
MoneyFor
Thanks !
That makes it a bit easier, now I can get replacement bolts before removing the db killer
Old Aug 7, 2019 | 01:07 AM
  #56
Sliceoflife
Thanks !
Consider that 4 mm and 5/32 (3,968mm).inch are quiet similar... strange to me they product to different kind of components
Old Aug 7, 2019 | 03:07 AM
  #57
Cardavidson's Avatar
Cardavidson
Well, solved the mechanical problems, I would like to ask you, MoneyFor, for the papers..Have you received the certificate of conformity (as a compliance report)? In Spain we have mandatory periodic reviews, and that certificate is mandatory (in theory signed by an approval laboratory)
Old Aug 7, 2019 | 05:11 AM
  #58
Mchad's Avatar
Mchad
@Mchad can you post the length of that part please
147mm from inside of flange to end of the tube.
Old Aug 7, 2019 | 06:42 AM
  #59
OldMike's Avatar
OldMike
In the US we use that term for something else.
We use a "center Punch" to center the drill.
Old Aug 7, 2019 | 12:17 PM
  #60
MoneyFor's Avatar
MoneyFor
Yep thats it , had heard it before but could not remember it
