2018+ Softail Models Breakout
What battery?
Old Aug 7, 2019 | 08:11 AM
fat booby's Avatar
fat booby
6th Gear
Default What battery?
What battery do the new softails come with, AGM??
i have to choose a setting on the trickle charger.
Old Aug 7, 2019 | 08:15 AM
Agoober's Avatar
Agoober
This one https://www.harley-davidson.com/stor...12-6598997c--1
HTH peace.
Old Aug 7, 2019 | 08:21 AM
Las Vegas Jim's Avatar
Las Vegas Jim
Yes, they come with an AGM battery.
Old Aug 7, 2019 | 03:50 PM
fat booby's Avatar
fat booby
6th Gear
Cheers guys
Old Jan 27, 2021 | 05:41 PM
sisdavid's Avatar
sisdavid
Okay, here are some videos of my new battery.
Old Jan 27, 2021 | 05:49 PM
TriGeezer's Avatar
TriGeezer
Dont use a trickle charger! Use a battery tender. A trickle charger is for charging, not for long term battery maintenance.
Old Jan 28, 2021 | 06:02 PM
sisdavid's Avatar
sisdavid
This battery from BatteryMart.com doesnt work. It barely cranks over a little then click click click. Put it on my battery tender let it charge back up then the same thing kinda turns over a little then click click click WTF. Can I jump my bike off of the car with jumber cables? I have done it before. If I remember right it cranked kinda slow on the car jumper cables. Could it be my starter? Also, is it okay to jumb off of the car or will it mess things up?
Old Jan 30, 2021 | 11:56 AM
tmac00333's Avatar
tmac00333
Don't do it, it will mess things up. Also, check the voltage on your battery with a voltmeter from any hardware store, the tender might not be bringing it up to full charge. Or it might just be the wrong battery, that's what it sounds like.
Old Mar 15, 2021 | 08:34 PM
jc15025's Avatar
jc15025
Veteran: Coast Guard
If you have a agm battery this is what you need. Bought it at Christmas!
Deltran Battery TenderŽ automatic/smart 12V, 800mA, Lead Acid/Lithium Selectable Battery Charger. Plug it in turn it on and walk away!!!!!!!
FenderGuy53
Jan 17, 2025 01:12 PM
gforce29
May 14, 2012 03:01 PM
Siberianhusky
Mar 22, 2009 07:58 PM
alfalfa
Mar 13, 2009 03:55 PM
nutmagnet
Jul 7, 2008 07:23 PM
