2018+ Softail Models Breakout
pull back risers for sport glide
Old Jan 1, 2020 | 09:32 PM
Jnaugle's Avatar
Jnaugle
Does the stock bar work with the 4“ risers and can i use the stock bar clamp?
Old Jan 1, 2020 | 10:14 PM
Moose328's Avatar
Moose328
the fat risers work with the stock bar, but from what I understand the stock top clamp doesn’t - you have to use the new one supplied with the new risers
Old Jan 2, 2020 | 10:42 AM
BuddyB's Avatar
BuddyB
Default 5" risers
I just put on the 5" risers. Brought it up and back a bit. But I'm still not finding it as comfortable as I had hoped. No change with any lines. I'm wanting something higher and will let me sit even more upright. I'm 5'11''. Anyone have any suggestions?
Old Jan 2, 2020 | 10:55 AM
El_M0to's Avatar
El_M0to
I'm 5'8" and got the 4" up and 2" back risers with the stock bars and I'm pretty happy with it.
Old Jan 3, 2020 | 04:48 PM
Royce's Avatar
Royce
I'm running the 2" Rox Risers on my bike. I'm 6' tall and they put me in the perfect riding position. Good points: you can rock them forward or backward if you need to slightly change the angle; you don't have to replace cables; you can keep the stock HD riser clamp. Bad points: they're not as streamlined as some other solutions.
Old Jan 4, 2020 | 03:00 AM
Moose328's Avatar
Moose328
You didn't have to change the stock bar did you? It didn't say on H-D's website what diameter bars the 5" risers were for. I'm getting my 4" pullback risers put on next week. Hopefully they'll be tall enough so I don't have to slouch anymore.
Old Nov 9, 2020 | 10:58 AM
Quaamik's Avatar
Quaamik
Stage I
Im looking to pull mine back with little or (ideally) no added rise. Is there anything that anyone has found that is less than the 4" riser? I'm 5'4" and while the height pretty good, I'd like a little less reach.
Old Nov 9, 2020 | 01:10 PM
LaRSin's Avatar
LaRSin
Where did you get the 4" pull back risers
Old May 24, 2022 | 06:06 AM
Ridingpanda's Avatar
Ridingpanda
Stage IV
Originally Posted by felix27
5’5 here. I could use another inch or so but it’s fine for now. Reduced reach seat would probable do it.
Hi. Fellow vertically challenged rider here, at 5'1...did you find a solution? I'm still looking around.
From what I've researched, will likely need at least an inch of rise to prevent the bars from hitting the tank when turning.
almasola2008
Feb 14, 2020 02:01 AM
gwstang
General Topics/Tech Tips
Oct 13, 2019 08:13 PM
jtp1984
Mar 11, 2013 04:21 PM
bfoster613
Nov 20, 2012 05:50 AM
boneman171
Mar 17, 2009 06:59 PM
