2018+ Softail Models Breakout
Final help point for apes
Old Apr 20, 2020 | 09:16 AM
Dcz28's Avatar
Dcz28
Default Final help point for apes
alright so got my 14in apes put on and now there's a check engine light. So been searching around and everyone is saying its common green clip for throttle. Now comes the help....i did not wire the bars themselves just plugged them into the ecu, so where is this green clip...at the harness or in the bars?
Next, most people were saying with this they had issues with sluggish throttle and mine was working fine even ripped it around the block. So could it just need a clearing of the code?
FYI. Battery was disconnected during the install except when plugged in wires to double check turn signals then disconnected again
I plain to read the code incase its for something else and making this a complete waste of time. So really I am wondering about this green clip everyone is having issues with.
thank you
Old Apr 20, 2020 | 10:47 PM
blh1972's Avatar
blh1972
Clear the code and see if it comes back, green plug is inside the handle bars for throttle by wire
Old Apr 21, 2020 | 06:24 AM
Dcz28's Avatar
Dcz28
Thanks I am hoping the clearing is it. Do I have to take the whole bars off again or can I get to it by taking the throttle side componets off?
Old Apr 28, 2020 | 12:15 PM
cembandit's Avatar
cembandit
Very common.
if you plug the battery in (why not just pull main fuse?) during install, the system will log codes related to missing fuel tank sensor and odomoeter.
hold the menu button on left control and turn the bike on - don’t start it.
cycle through and see which module says YES, then hold menu on that to get the code or codes for each module - take a photo.
then clear the codes (hold menu again) after looking them up and ride a bit - be wary if you have abs codes.
Never turn the bike on when brake lines are not on and flushed, when the bike is turned on the abs modules pulse and could draw air.
Old Apr 28, 2020 | 12:40 PM
Dcz28's Avatar
Dcz28
Originally Posted by cembandit
Very common.
Well I am new to harley and never done a swap figured just pulling battery would do it.
Ended up clearing and codes stayed away so thats good. Bike is none abs don't know if that matters to your statement on drawing in air.
And took it for a ride and popped rear tire so now I have lol.
Old Apr 28, 2020 | 12:43 PM
cembandit's Avatar
cembandit
Sounds like your set. Ride well.
edit, thought you said popped up the tire as in a wheelie.
SFYL
Trido
General Topics/Tech Tips
Sep 21, 2016 08:45 PM
RCopeland1
2014-2024 Touring Models
30
Nov 11, 2015 08:53 PM
harleyglen
Apr 10, 2014 01:52 PM
amike
Feb 2, 2013 06:19 AM
mike5380
Feb 25, 2012 11:12 PM
