Clear the codes then check to see if they come back after starting. The codes there because you disconnected plugs during installation. If everything is connected back they will disappear. If not then you have to see what the code is for.
Ecm P0463h not in my list U0156h lost Comm with Speedo Bcm B2116h fuel pump output open U0156h Lost comm with Speedo
OK cool I didn't know if it would be smart just to clear them so wanted to run it by people more knowledgeable then me. 2 are for fuel and other I think speedo. So I will try that thanks
just clear them. If it's still a problem they will come back. See my edit above on what they are for. You listed the same code twice under BCM and ECM
Pretty much guessing there are (1) bad connections, (2) bare wires/shorts, or (3) incorrect connections. Re-trace your steps, check all the wires/harnesses & ensure it's all 100%.
