Rear Shock Preload
So, my bike came on 2. I read the manual and set it at 1. I was constantly bottoming out, which hurts and scraping the footboard. I set it to 4. Much more comfortable and on a spirited ride with mates around lots of twisties, only scraped once. Handling is good. One mate reported I was very close to touching exhausts down on right handers. Out of interest I increased preload to 6 and on a shorter ride on Thursday, it was comfortable, perhaps even better. At settings 4-6, I am no longer bottoming out the rear and as a bonus, less likely to scrape the footboard. I will leave it at 6 for now, knowing that if I need it, setting 4 works for me. Might be easier to get my lift under the bike too!
I definitely read things (performance upgrades usually) and think, 'no way you can tell, it's just in your head'. So, possibly it's in my head. But I honestly dont think so. Cost me nothing, nothing to prove!
The front is sprung a little soft but I've added 20mm(3/4 inch) of oil in each leg and about 12mm(1/2 inch ) of preload with spacers but it doesn't slam through the stroke like the back end. Out back if I hit a square edge bump it just blows through the damping and bottoms hard.It might need a stiffer spring.
Does anyone know the spring rates for these things ?
