2018+ Softail Models Breakout
Question about risers and and ABS brake cable / clutch cable
Old Jul 6, 2020 | 11:27 PM
gthmnyt2580's Avatar
gthmnyt2580
Default Question about risers and and ABS brake cable / clutch cable
I just picked up a set of Drag Specialties 4 1/2 risers off of Ebay for my 2020 Slim for a decent price. I should be getting them later this week and was hoping to install them before the weekend.
https://www.dragspecialties.com/sear...umber-06020409
I'm noticing now that some people say that you have to re-route the stock brake and clutch cables and some people say you don't. With that being said, my Slim has ABS brakes equipped so I'm not sure if that makes any difference in terms of the brake cable length. Anybody manage to make the stock cables WITH ABS brakes work with 4 1/2 risers and if so, how?
I should also note that I'm keeping the Hollywood bars on there.
Thanks in advance!
Old Jul 7, 2020 | 01:10 AM
Agoober's Avatar
Agoober
Thinking you might have to get a longer brake cable man and maybe clutch too.
The boys will know.
Old Sep 19, 2020 | 10:29 AM
Rob Cor's Avatar
Rob Cor
5th Gear
Default Wiring and cables
12” risers narrow bars on my FatBob 114. Required upper brake line (ABS) and upper clutch cable. However if you route the clutch cable on
the right hand side of bike you may be able to get away with not buying the clutch cable upper part. Use a string to measure from the bottom of triple tree for ABS brakes or caliper on non ABS system. Magnum Chromite II is what I went with for the ABS.
Old Sep 19, 2020 | 10:58 AM
LaRSin's Avatar
LaRSin
From what I understand you just have to reroute the clutch cable , And a new top clamp , as the drag sp. is angled .
check the last post on this thread , I'm going to do the same thing , Just not sure which one to go with HD or Drag
https://www.hdforums.com/forum/2018-...ar-change.html
762mm
Mar 4, 2019 05:05 AM
Ausreed93
Jan 19, 2019 12:56 PM
pigfoot63
Mar 26, 2017 10:41 AM
Dhock83
General Topics/Tech Tips
Mar 21, 2017 04:27 PM
Black Sunshine
Oct 5, 2012 05:06 PM
