2018+ Softail Models Breakout
FXBB speedo
Old Jul 20, 2020 | 06:54 AM
Riotfunk's Avatar
Riotfunk
Default FXBB speedo
Anyone know if there’s different speedo combo vs the oem tiny digital one. Or a way to make it brighter or change the color. I’d rather an analog tach and digital display like you can get for the 48/and fat boy I believe. Hard af to see in the sun even with front fairing and bar bag blocking light from the front. And tinted visor on my helmet. I’m looking for plug and play like in other models so I don’t lose the minimal functions this has.
Old Jul 20, 2020 | 08:58 PM
Moose328's Avatar
Moose328
So there IS a way to do a dual gauge setup on the new FXBB. I recently did this with my FLSB, I'm running gauges from an FXLR on my bars now inside some gauge pods from Speed-Kings Cycle. You can get the gauge pod bracket kit here and order a set of gauges from an FXLR from Harley (if you do this, you'll need front and rear gaskets. PN's are 2 of 67121-95A, 1 of 70900729, 2 of 67104-95, and 1 of 70900697). You also need a speedometer cable from Guerrilla Cables for an FXLR if using FXLR gauges (included in the Speed-Kings cycle link I posted). If you're not changing your bars, just get a standard top clamp from Bung King and mount the gauge pod bracket to the top clamp.
Or, if you want a single gauge set up, Guerrilla Cables lays out everything you'd need here. If you have any questions just call them, they're super helpful on the phone.
Good luck! Changing from a tank mounted set up on my FLSB to a bar mounted setup is probably the most favorite thing I've done.
Old Jul 20, 2020 | 09:26 PM
Ralibur's Avatar
Ralibur
I agree with "Changing from a tank mounted set up on my FLSB to a bar mounted setup is probably the most favorite thing I've done"
I did the same to my Sport Glide and its great to see the instruments pretty much straight on.
Old Nov 4, 2020 | 06:34 AM
RoxSy's Avatar
RoxSy
Hi Sir !
Thank you for those informations.
I have In Heritage Classic and would like to do the same mod as you did, i.e. putting my gauges to the handlebar clamp without changing it.
You say you went from a FLSB to dual FXLR gauges.
Why didn't you keep the stock FLSB Speedo ?
Problems with diameters and functions ?
Thx !
Simon
Rick341
Feb 26, 2013 12:20 AM
Mike NY
Jan 4, 2012 01:33 AM
fathertime
Feb 19, 2010 01:48 PM
jjr
Sep 7, 2008 08:45 PM
songsmith
Feb 17, 2008 02:06 PM
