2018+ Softail Models Breakout
buying 2018 low rider
Old Jul 25, 2020 | 08:41 PM
falikmike's Avatar
falikmike
Default buying 2018 low rider
any problems that is known with it that i should watch out? Are the stock rims any good?
I am selling my street bob and buying low rider.....also what is the difference between lowrider S and lowrider....
Old Jul 25, 2020 | 09:32 PM
Modo's Avatar
Modo
S has 114ci engine, dual disk front brakes, inverted forks, blacked out engine/exhaust, different rims, headlight fairing, blacked out console and fender struts, smoked tail light, black primary cover, think thats about it.
Old Jul 27, 2020 | 06:45 AM
Gorion's Avatar
Gorion
Veteran: Coast Guard
Have had my 2018 Lowrider for 2 years. No complaints so far.
Old Jul 27, 2020 | 08:26 AM
ss3964spd's Avatar
ss3964spd
I've had my 2018 LR for just over two whole months. Also no complaints.
Old Jul 27, 2020 | 12:43 PM
Las Vegas Jim's Avatar
Las Vegas Jim
Thumbs up M8 Low Rider is a Solid Bike
I have owned my 2019 Low Rider for one year and have put about 5.5k miles on it. VERY satisfied with the bike; it is the correct bike for me because of the mid foot controls and its improved low center of gravity. No problems with stock rims. But, I have make a few changes.
1. The Stage 1 upgrade opens up the air flow to improve throttle response, acceleration and engine temp in hot weather.
2. Replaced the OE seat with a Mustang seat. Both Mustang and Saddlemen make solo and 2-up seats that improve personal fit & comfort. Plan to replace seat.
3. The OE brake pads have an established history of squealing, poor rear brake performance and causing excessive rotor wear. Plan to replace them with Lyndall Gold+ pads.
4. Check the height of the rear brake foot peddle. (See multiple posts on this subject.) Many people find that it needs to be adjusted to a higher position to effectively use rear brake. No big deal; easy adjustment.
Either verify that the 1k inspection had been performed or plan to have it performed before buying the bike. The 1k inspection is where all of the adjustments after brake-in get made and any initial warranty issues are found and corrected.
Good luck; I predict you will like the bike. The M8 engine and 6-speed transmission are wonderful.
Old Jul 27, 2020 | 03:48 PM
SS Twin's Avatar
SS Twin
Have had mine for 3 months, 1000 miles. Total of 5K on the bike and it is a hoot. Bought it with lots of extras and a Stage 2 setup with Woods 22-X cam. Great performance and fun. Best Harley I've owned and all the priors were good bikes as well. I do have the foggy speedo when exposed to sun for a while. OTW it is a treat. You won't regret it.
Old Jul 27, 2020 | 06:23 PM
P51Driver's Avatar
P51Driver
Composite (plastic) intake manifold. Problematic, but that is the case with all stock M8 engines.
Old Jul 28, 2020 | 08:26 AM
ss3964spd's Avatar
ss3964spd
What's the reported problem?
Old Jul 28, 2020 | 12:03 PM
SVTII's Avatar
SVTII
I bought my first Harley in January which was an Iron 883. Three weeks later, I traded it for a Low Rider and haven’t looked back. Got almost 5k on it with no issues other than a bit of brake squeal like was mentioned earlier. The only things needed are add-ons and other things to make it more comfy. I’m very happy with mine!
Old Jul 28, 2020 | 03:21 PM
Breizh Rider's Avatar
Breizh Rider
Very happy with mine, too. Very easy to run and fun too.
Replaced the non-existent front fender. It can be rainy in Bretagne.
Next step : stage 1. But parts are not available in France at this time...
