2018+ Softail Models Breakout
Installed new handlebars left taillight not on.
Old Jul 29, 2020 | 09:49 AM
Retrovicious's Avatar
Retrovicious
Stage III
Default Installed new handlebars left taillight not on.
Hello I'm a new owner of a 2020 breakout and installed new bars i believe I installed everything correctly checked the lights before I put everything back together and was working, once everything was put back together the left tail light is completely inoperable no idea what to do next. I'm also getting fault codes B2151c and B2176h
Old Jul 29, 2020 | 10:12 AM
ss3964spd's Avatar
ss3964spd
Do you mean the left rear turn signal?
Old Jul 29, 2020 | 10:13 AM
Retrovicious
Stage III
The left rear brake/running light and turn signal is completely inoperable everything else works fine.
Old Jul 29, 2020 | 10:19 AM
ss3964spd's Avatar
ss3964spd
As a test, turn the Run switch to "On" and and activate the 4 way flashers. See if the left rear flashes.
Old Jul 29, 2020 | 10:26 AM
Retrovicious
Stage III
I did that and the left light doesn't work at all also getting codes B2176h and B2151c.
Old Jul 29, 2020 | 10:51 AM
ss3964spd's Avatar
ss3964spd
On a stock bike only the center/fender mounted lamp acts as a running and brake lamp. The left and right rears only work as turn signal lights. The BCM (body control module) can be re-programed to make the left and rear lamps also act as brake lamps but, since they are single filament bulbs, they cannot act as running lamps.
The left and right front lamps act as running and turn signal lamps. If the left front does still work correctly my first guess is left rear bulb has gone bad.
Old Jul 29, 2020 | 01:29 PM
Tampa Fatboy's Avatar
Tampa Fatboy
I'm guessing you had to extend the wiring which means you had to pull the pins from the connectors. Wire pin didnt get put back correctlly my thoughts, easy to do, I'm guilty...*laffs
Old Jul 29, 2020 | 05:41 PM
24v's Avatar
24v
Breakout doesn't have a center mounted light.
Old Jul 29, 2020 | 05:53 PM
ss3964spd's Avatar
ss3964spd
Right, thanks for that, thought the center light was federally mandated.
I'll go back to my corner now.
LIMike
Dec 9, 2018 07:07 AM
Mobeus102
Touring Parts
Nov 25, 2018 11:32 AM
Erock1800
Jan 18, 2014 08:23 AM
girsik
Electrical/Lighting/Alarm
Feb 17, 2013 03:40 PM
motox285
Mar 3, 2008 12:23 PM
