2018+ Softail Models Breakout
Strange front end bounce 2020 FXLR
Old Aug 9, 2020 | 11:57 AM
Fuzzy-1's Avatar
Fuzzy-1
Default Strange front end bounce 2020 FXLR
2020 FXLR with 1,500 original miles. At around 50 MPH the front bounces as if I ran over 4-5 rounded one by fours spaced 2 feet apart on the road. It then rides smooth for 25 yards and will repeat the cycle again for ever. If i go faster, the cycle starts sooner. It does this when i engage clutch and coast. I slightly engaged the front break at 50 mph, and it happens the same way. I don’t think it is the breaks or the engine. The dealer balanced the tire to no avail. I don’t feel it at 40mph or slower.
Any feedback would be appreciated.
Old Aug 9, 2020 | 12:58 PM
OldMike's Avatar
OldMike
I think there was a post here about defective tires that balancing could not fix, maybe somebody has more info can post about this.
https://www.hdforums.com/forum/2018-...-2020-lrs.html
Old Aug 9, 2020 | 02:16 PM
Tozco's Avatar
Tozco
It could be an out of round front tire that can't be balanced when it is running on the road. Try to look at the shadow your front wheel makes when riding at the problem speed and look to see if your wheel is bouncing on the pavement. When you pull in the clutch lever, you are disengaging the clutch.
Old Aug 9, 2020 | 04:25 PM
AJ88V's Avatar
AJ88V
2020? Straight to the effing dealer. It's wrong. They fix it.
Old Aug 9, 2020 | 05:48 PM
nightsterept's Avatar
nightsterept
See the post that OldMike referenced, that was my bike originally and your situation sounds very, very similar.... It could be a bad inner belt in the tire, or out of roundness outside of spec. A tech can attempt to balance the wheel till they are blue in the face....it won't fix the issue if it's the tire itself. Also see the very last post on that thread, there are new tire part numbers referenced from Harley. This is a known issue that the dealer should correct for you.
Best of luck
Old Aug 14, 2020 | 06:51 PM
Fuzzy-1's Avatar
Fuzzy-1
Thank you all for the feedback. Dealer has the tire on order, should be In next week. Keeping my finger crossed.
Old Aug 20, 2020 | 06:07 PM
Fuzzy-1's Avatar
Fuzzy-1
The dealer installed the new front tire under warranty yesterday. No more bounce. Thanks again for your reolies.
Old Aug 21, 2020 | 07:50 AM
nightsterept
Awesome news, glad you were in the same boat as me and just needed a tire replacement. Enjoy the ride!
Old Aug 21, 2020 | 11:11 AM
FattyMcJ's Avatar
FattyMcJ
Glad you got it fixed. Also glad it's not the actual wheel, just a crap tire.
Mystic_3D
Jan 30, 2019 07:03 PM
Huggerbugger
Dec 16, 2017 02:19 PM
donttreadonme
Jun 2, 2012 07:23 AM
nikom74
Dec 31, 2006 05:26 PM
Rick51
Jul 3, 2006 01:25 AM
