2018+ Softail Models Breakout
Thought modern Harleys don't leak oil? Think again!
Old Aug 22, 2020 | 12:06 AM
RossW's Avatar
RossW
Default Thought modern Harleys don't leak oil? Think again!
And here I was thinking oil leaks on relatively new bikes went out with Shovelheads
Looks like the base of the pushrod tubes is leaking
107 Sport Glide with 5500 km (3300 miles)
Old Aug 22, 2020 | 12:34 AM
2018 lowrider M8's Avatar
2018 lowrider M8
Well that Sucks Have you recently done an oil change and overfilled it ,just a thought
Old Aug 22, 2020 | 12:46 AM
RossW's Avatar
RossW
No. I check it regularly but haven't needed to add any since it got its first service at the Dealer. There is no sign on the engine itself above the base of the pushrod tubes and it appears to be leaking there. The level in the oil tank is about halfway up the dipstick.
There is some oil coming from the filter because I thought t was a K&M one (SE Stage 1) and oiled it. That oil is pink, and the oil below the pushrod tubes is not. Still now that I've cleaned it all way I'll see if it comes back and where. The breathers are clean as a whistle.
If it keeps leaking I'll be taking it up with the dealer at the next service, but ultimately I'll be putting an external breather on it when the warranty runs out.
Last edited by RossW; Aug 22, 2020 at 01:17 AM. Reason: Not sure if the filter is supposed to have oil.
Old Aug 22, 2020 | 04:26 AM
Durham man's Avatar
Durham man
My Evo fxr leaked from the tappet block so I tighten it down a hair (light crack on each bolt) and it stopped leaking.
Old Aug 22, 2020 | 07:18 AM
Tampa Fatboy's Avatar
Tampa Fatboy
It's under warranty I take it, why havent you had service deal with it?
Old Aug 22, 2020 | 08:34 AM
RossW's Avatar
RossW
Its Saturday and I only discovered it today.
Old Aug 22, 2020 | 08:37 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The title to your post was a bit dramatic, don`t you think?
Just because your bike may have developed a leak does not mean new Harleys leak.
It`s an isolated case, any machine that uses fluid can leak. It happens.
The dealer will take care of it.
Tampa Fatboy
ouch...I hate that.
Old Aug 22, 2020 | 09:02 AM
OldMike's Avatar
OldMike
I'd say pink oil is still going to appear black on the engine case, it's not paint.
That oil dripped from your air filter is my guess. Think about a new air filter.
Old Aug 22, 2020 | 09:06 AM
Uncle Larry's Avatar
Uncle Larry
Well ... it's definitely coming from above the lifter block base gasket ... Definitely not a "The sky is falling" moment :>)
