Anyone else struggle with Eliminator 300 install?
Got the lower muffler baffle done no problem.
Upper end cap came out and I discovered the clear wrap around the fabric packing had perished inside (its like shrink-wrap to keep the fabric tight) as the baffle came out which led to the packing coming loose and stopping the existing baffle from sliding back in. It only needs to come out a few inches to install the quiet baffle but there was no way it was going back in.
Fortunately the replacement muffler V&H sent due to the original one rusting is arriving tomorrow so Ill install the quiet baffle before I install the muffler.
Fingers crossed Ill be able to report back on performance tomorrow.
EDIT: Just repacked the muffler, so Ive got a spare, but Ill wait for the new one to show up.
Its made harder by the fact the finish on the end caps (mine are black) is incredibly fragile so you cant use any kind of prying tool to help ease the caps off, the slightest scrape will mark the end caps.
The reason its tight is partly the cap inside the end of the muffler body, but mostly because the baffle wadding is very tight around the main baffle.
I used the rubber handle of a big hammer to help grip the inside of the baffle tube and carefully pull the assembly out.
To save yourself the hassle of having to repack the baffle with the fibreglass, only pull the baffle out as far as you need to remove the three bolts in the back. Also only rotate it in the direction the baffle is wrapped, if you feel resistance then it may be the wrong way.
I also needed to use a board wrapped in a towel with a mallet to get them fully reseated.
Id say its probably a lot easier to do it with the mufflers removed, but as per the beginning of this thread, theres no way I was going to do that.
If the end caps came out easy its a 15 minute job. Your mileage may vary!
Firstly, they are definitely quieter, probably somewhere between stock and no baffles. I dont mind it as Id warmed to the stock pipes anyway.
Secondly... its transformed the performance of the bike, especially with the FuelPak map. Honestly I was expecting a minor improvement, but the low-mid range torque difference is huge.
Im not just saying it, the difference is incredibly noticeable.
Firstly, they are definitely quieter, probably somewhere between stock and no baffles. I don’t mind it as I’d warmed to the stock pipes anyway.
Secondly... it’s transformed the performance of the bike, especially with the FuelPak map. Honestly I was expecting a minor improvement, but the low-mid range torque difference is huge.
I’m not just saying it, the difference is incredibly noticeable.
However, like a dumb *** I ***umed if you order baffles for specific mufflers, in this case Eliminator 300s, which there are TWO of them, you'd get TWO baffles. Wrong!
My other baffle won't be in until Monday, so I wait...
I used a hammer and a screw driver (with black electrical tape over the blade) to loosen and remove the end cap from the chrome over tube. Minimized damage to the end cap. Getting the end cap and and new "quiet baffle" back in required a lot of hammering with a piece of wood actually contacting the end cap.
I'd love to tell you how it sounds, but I can't. Tried to start the bike up and run it, but the FP3 I put on last night is messed up, and now the bike (2018 FLHCS, Heritage 114) will not start. Spent over an hour with Vance & Hines Tech Support to no avail. They are overnight shipping me another FP3. We'll see how that goes tomorrow.
The saga continues...
