2018+ Softail Models Breakout
Cam swap
Old Dec 1, 2020 | 04:15 AM
irish44's Avatar
irish44
Default Cam swap
I'm looking to switch my s and s 465c cam to the cycle rama 480. Can I reuse the pushrods and the tappets? It been in the bike for about a year
Old Dec 1, 2020 | 07:24 AM
nightsterept's Avatar
nightsterept
I’ve asked this same question and received generally the same answer from tech experts and local shops:
General opinion is pushrods yes can be reused if adjustable and in good shape. You could technically reuse your tappets if no unusual wear; however, most will advise to replace them along with your cam. Also, if you’ve already replaced your cam bearing with a full compliment bearing, you can reuse it.
But, by all means consult an expert or forum supporter like Fuel Moto
Old Dec 1, 2020 | 07:44 AM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
best practice is always to replace the tappets with the cam. They break in together.
If you have adjustable pushrods, You should be able to re use them.
Feuling has HP+ full travel liters for 160$ https://www.feulingparts.com/sku/4000
FuelMoto has adjustable pushrods for 160$ https://www.fuelmotousa.com/i-208594...m-engines.html
Old Dec 1, 2020 | 04:00 PM
Tampa Fatboy's Avatar
Tampa Fatboy
It all depends on mileage, wear and tear. Low mileage you can by without.
EDIT: Adjustment on the push rods is always key, not everyone is able to get them right.
Old Dec 2, 2020 | 02:22 AM
Guglielmo Marconi's Avatar
Guglielmo Marconi
some serious reason to switch 465 to 480? i have 465 also, just interesting.
JAMESRH78
Engine Mechanical Topics
11
Feb 20, 2020 07:02 PM
Bikerscum
2014-2024 Touring Models
Jun 7, 2015 09:53 PM
Rogue8Man
Oct 26, 2014 06:08 AM
Kees
EVO
90
Dec 7, 2013 01:32 AM
WildBill527
EVO
Mar 5, 2009 12:21 PM
