2018+ Softail Models Breakout
Lithium battery I think problems
Old Mar 19, 2021 | 02:57 PM
Mikecannon1222@gmail.com's Avatar
Stage III
Default Lithium battery I think problems
I just put a new lithium battery in my FXLR I drove it about 20 miles, I turned it off at gas station, tryed to start it back up the solenoid started clicking. It stopped for about 15 seconds and started clicking again all by itself and it did this for about an hour before l could get a wrench to unplug the starter, any body got any ideas, I've totally upluged the starter switch and there's still power on the starter wire???
Old Mar 19, 2021 | 03:02 PM
MURPHCC1's Avatar
MURPHCC1
You're first post since joining 5 years ago........
Welcome aboard from Old Cape Cod!
Old Mar 19, 2021 | 03:25 PM
squirrelsnest's Avatar
squirrelsnest
Welcome to the forums from Virginia..............
Old Mar 19, 2021 | 06:07 PM
SoCaRider's Avatar
SoCaRider
Check Voltage on Battery ?
Old Mar 19, 2021 | 06:47 PM
Agoober's Avatar
Agoober
Whatever reason you had to change the battery is still there mate.
Old Mar 20, 2021 | 08:37 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Unless you disconnect the positive cable from either the battery post or the starter solenoid, the big wire going to the starter will be live...
What year bike?
How old is the battery?
Take the battery to an auto parts store and have them load test it (make sure it is fully charged first).
Clean all battery cable connections, both negative and positive.
Old Mar 20, 2021 | 10:27 AM
natural gasser's Avatar
natural gasser
Did you fully charge the battery with the appropriate charger? Lithium need a different charger/tender. If it's pretty cold out, a lithium needs to warm up. Turn on the power/lights let it sit for 5+ minutes.
Old Mar 20, 2021 | 10:33 AM
TriGeezer's Avatar
TriGeezer
But, the starter solenoid clicking all by itself wouldn’t be caused by a battery.
Old Mar 20, 2021 | 10:35 AM
LaRSin's Avatar
LaRSin
Have you disconnected the battery to let the starter disengage ? .
Old Mar 20, 2021 | 04:48 PM
Stage III
It's a 2018 FXLR yes I've tried everything I could think of . It all started with that lithium battery, I think I just got a bad one, I've had others with no problems, will get a regular matenence free battery and start over. Thank you all for the feedback!!!
