Hi, new here so I hope I'm doing this right. Bought a 2020 streetbob last year with 400 miles on it. Just has a stage 1 kit with SE high flow intake, and V & H short shots. The bike was tuned at the dealership. My problem, I finally get the bike out ( I live up in the rocky mnts so the roads finally cleared up enough to ride a bit) and I get a engine check light. So I go through the process to look up the codes and this is what I have.
P0503h VSS Sensor high/open
P0131h Front oxygen sensor low/engine rich.
Kinda early to be poppin codes, anyone else run across this?
Sry if I posted in the wrong spot, like I said, new to the forums. Thanks in advance.
[QUOTE=Beau Dawg;19836875]Hi, new here so I hope I'm doing this right. Bought a 2020 streetbob last year with 400 miles on it. Just has a stage 1 kit with SE high flow intake, and V & H short shots. The bike was tuned at the dealership. My problem, I finally get the bike out ( I live up in the rocky mnts so the roads finally cleared up enough to ride a bit) and I get a engine check light. So I go through the process to look up the codes and this is what I have.
Beau[/QUOTE
Texted my salesman,, he's pretty awesome... found out that if you have an h behind a code...its a historical code... he suggested I clear it and run the bike to see if the pop up again... did it and they stayed gone.. all is well in the north pole..
