2018+ Softail Models Breakout
Signal Relocation
Old Apr 18, 2021 | 10:01 AM
pjbuilder's Avatar
pjbuilder
Default Signal Relocation
I purchased a batwing fairing for my Sport Glide. Has anyone relocated their signals without doing a cut and splice? If so I'd appreciate knowing how you did it. I've searched and it looks like there maybe a molex connection under the tank that I might be able to depin in order to pull wires through bars.
Thanks
Old Apr 18, 2021 | 10:43 AM
OldMike's Avatar
OldMike
Thanks
Yes, I did this a couple of times.
I lift the front of the tank to get to the junction block under the rubber boot. Unplug the two turn signal plugs. There is a small trap door on top of the plug I lift and work the wires through, and pull back the rubber gasket, save the little white dummy pin. Some people just cut the hinge on the trap door to make it easier.
I use a small safety pin (not jewelers screwdriver) to unlatch the tang while using a bit of tension on the wire to feel when it is free. Be gentle with the pin, you'll feel when you have ahold of the tang you need to lift. Take pictures to keep track of pin location in the plugs. This diagram helped me the most to understand the working of the plug and pins:
Old Apr 18, 2021 | 05:19 PM
Mallard Slayer's Avatar
Mallard Slayer
here is a awsome video I found on the tube that explains it clearly and it is done by a very talented member of the this forum!!
Thanks Mud for the very helpful video!!
Old Apr 18, 2021 | 09:17 PM
pjbuilder's Avatar
pjbuilder
Thanks much. That's what I was expecting but not sure. I plan on keeping the signal wires the original length in case I decide the batwing doesn't live up to expectations and I decide to put signals back to the original location.
Old Apr 22, 2021 | 01:21 AM
Topher C's Avatar
Topher C
I fork mounted my fronts, and did an all in one rear brake light / rear delete
Comb
Sep 16, 2020 07:14 PM
snakeyes
May 15, 2011 06:59 PM
Rick7938
Mar 16, 2011 09:43 PM
painguy
Mar 19, 2009 03:44 PM
jason55w
Nov 24, 2008 07:22 AM
