2018+ Softail Models Breakout
4" Oil Filter
Old Apr 22, 2021 | 09:43 AM
Las Vegas Jim's Avatar
Las Vegas Jim
Question 4" Oil Filter
Time to change my fluids. I have a 107 engine with the pre mid-2019 oil pump and a Stage 1 upgrade. Anyone used the new 4" HD oil filter recommended by HD in their 2020 Service Bulletin? Any noticeable effect on engine temperature?
Old Apr 22, 2021 | 10:00 AM
Tampa Fatboy's Avatar
Tampa Fatboy
yes, part # 62700296, service and parts should be giving you this filter. they were issued a service bulletin to do so last year
Edit: the new oil pumps were not installed on the M8's until somewhere around June '19. date code on your down tube decal will have the production date. Regardless which oil pump, you should still be running the new filter
Old Apr 22, 2021 | 10:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
That filter will have effect on oil temperature.
Old Apr 22, 2021 | 11:39 AM
ss3964spd's Avatar
ss3964spd
Since the housing is larger and thus has more surface area to dissipate heat, technically it should lower the oil temp. I'd be surprised, though, if it did so to any noticeable degree.
Old Apr 22, 2021 | 11:42 AM
HuntWhenever's Avatar
HuntWhenever
I've been running the new filter for the past two oil changes. No differences noticed in running condition.
Old Apr 22, 2021 | 01:53 PM
SoCaRider's Avatar
SoCaRider
Just a little more oil is the only noticable difference
Old Apr 22, 2021 | 02:34 PM
FattyMcJ's Avatar
FattyMcJ
Old Apr 22, 2021 | 04:41 PM
Mart's Avatar
Mart
My 2020's been serviced by the dealer twice. Both times they used the old size filter. Can't say I'm losing any sleep over that 🙂.
Mertoid
Jul 17, 2018 09:58 AM
yzergod
Apr 2, 2014 09:50 PM
RoadKingHellas
Feb 10, 2013 12:24 PM
HDCB
May 27, 2007 03:30 PM
roadking1327
Oil Archive (no new posts)
14
Apr 2, 2007 05:30 PM
