Proper oil level with a mesh filter?
Old Jul 16, 2018 | 10:00 PM
Mertoid's Avatar
Mertoid
Default Proper oil level with a mesh filter?
Did an oil change today and installed a reusable mesh type oil filter. I put in the same amount of oil as always, 3 qts and 20 ozs. Warmed up the engine, waited a bit and checked the level. It's normally about halfway between the add and full marks. It was definitely over the full mark. I took out 8 ozs to bring it to just under full.
I'm wondering what the proper level should be now. Unlike a paper filter, the mesh filters have no anti drainback valve. So is whatever is in the filter going back into the sump when the engine is shut down? Or is the difference in oil levels simply due to the mesh filter's smaller size?
Anyone had this issue before?
Old Jul 17, 2018 | 12:56 AM
1Canuck's Avatar
1Canuck
The correct amount is where it should be on the dipstick.
Old Jul 17, 2018 | 04:11 AM
Campy Roadie's Avatar
Campy Roadie
I don't use re-usable filters so there may be a nuance that I'm ignorant of, but, I can't see how using one would change the recommended oil level.
Old Jul 17, 2018 | 04:13 AM
grbrown's Avatar
grbrown
Thumbs up
Agreed! I can't see that a change in type of filter should have any significant affect.
M, perhaps after a decent ride your new filter will fill with oil and you can top it up to a similar total quantity as before. Don't throw that 8 ozs away!
Old Jul 17, 2018 | 07:55 AM
Mertoid's Avatar
Mertoid
I'll definitely save the 8 ozs, it'll need it again somewhere around the 4k mile mark.
I'll leave it at the current level and check the air filter occasionally. The reason I run it a little short in the first place is due to the crankcase breather spitting it out into the air cleaner. The mesh filter has a smaller volume than a paper filter, so the system requires less oil in total.
Old Jul 17, 2018 | 09:34 AM
caulk04's Avatar
caulk04
No drainback valve?
Old Jul 17, 2018 | 09:45 AM
hattitude's Avatar
hattitude
Some media in the paper filters will absorb and hold oil, when first saturated with oil. When I pre-fill the large oil filter on my diesel truck, I can pour a full quart into the filter and watch it disappear as the filter media soaks it up. I can then turn it sideways and only a dribble might come out....
Since the mesh won't absorb & hold any oil, and if the filter has a smaller container than the OEM filter (OEM are pretty small), I suspect it could affect the amount of oil in the system..... seems unlikely it would be 8 oz.....
Bottom line, go by the dip stick...
Old Jul 17, 2018 | 09:51 AM
hbsoldier3's Avatar
hbsoldier3
I have a the K&P reusable filter on my 14 FLHTK. I don't remember any difference in oil quantity. However, I good be wrong, I use 3 qts 8 oz's to the full mark on the dipstick.
Old Jul 17, 2018 | 09:54 AM
Mertoid's Avatar
Mertoid
No anti drainback, just in through the 3 outer slots, back out through the threaded hole. I'm sure the oil level is reading high because of oil drainback.
What I'll have to do is measure the difference in volume between the old paper filter and the mesh one so I can have the proper oil level when the engine is running. I'll do that next oil change.
I was just wondering if anyone had noticed this difference before.
Old Jul 17, 2018 | 09:58 AM
Mertoid's Avatar
Mertoid
I agree, 3 qts 8 oz's is looking about right.
smokingjoe
Milwaukee Eight (M8)
37
Jul 24, 2017 10:44 AM
Timpechos
Jul 5, 2013 10:14 AM
RoadKingHellas
Feb 10, 2013 12:24 PM
LucyOnBlack
Oct 30, 2011 10:39 AM
HDCB
May 27, 2007 03:30 PM
