2018+ Softail Models Breakout
Rattling Heritage 2019
Old Jun 11, 2021 | 08:13 AM
Burbur2's Avatar
Burbur2
Originally Posted by Hulkss
Bend or twist the fork ears to fit snug in the groove of item 15.
Brilliant this is great tip thanks for sharing this
Old Jun 11, 2021 | 05:34 PM
Mart's Avatar
Mart
I get a rattle from my front brake rotor/disc. It's the self centering mechanism that's loosened up. I'm ok with it, now I know nothing's about to drop off 😁👍.
Old Jun 12, 2021 | 02:09 PM
PA1195's Avatar
PA1195
Originally Posted by Burbur2
I am sure someone already figured this out just not sure whats the fix. My saddlebags on Heritage rattle where lower arm goes into grove in the frame mount on the bottom. Thing drives me nuts. Whats the fix?
I also have some rattling sound up front at around 3000rpms. I already fixed both gas caps and tight all the bezels rings on front lamps so what is next to check?
Come on HD WTH?
I had a similar rattle 2900-3000 up front on a 2021 FLHCS Heritage after purchase. I used a soft rubber hammer and lightly tapped everything around the front end including the front forks and lights. My source of noise was where the front panel (61400458) that covers both the upper forks behind the headlight touched the left fork's round upper fork cover (45800110). From behind I pushed the panel cover away from the fork cover so there was a 1/8" space between them all around. The right side was ok. Tapping the nearby lights made no noise. Also my oil cooler cover was loose so I thread locked and tightened the lower screw then put some black RTV over the two tangs where the upper cover hooks onto the frame.
Edit: Parts Catalog https://serviceinfo.harley-davidson....99579872568598
Old Jun 12, 2021 | 03:05 PM
Burbur2's Avatar
Burbur2
big thanks for this tip. I actually replaced rear side of this fork cover on my bike so maybe thats why. I will definitely check this out. Appreciate your help and will report back soon
Old Jun 12, 2021 | 03:56 PM
PA1195's Avatar
PA1195
It looks to me that there needs to be clearance all the way around those round upper fork covers. If they can hit then tapping the cover will move it slightly and it'll make a buzzing noise compared with the other one that's quieter. I guess that's what the engine does at around 3K rpms....set up a frame shake that makes close parts contact each other. The rubber hammer test does work. My 114 does vibrate a bit more than the 107 Deluxe I had earlier.
Old Jun 13, 2021 | 02:53 PM
Uncle G.'s Avatar
Uncle G.
Buzzing and rattling of the fork cover/headlamp shroud was a common issue in my old FLSTN. The front cover was always working loose enough to rattle. It’s amazing how a noise like that will carry right to your ear over wind, engine and exhaust.
sherifflittle
Jun 14, 2024 05:19 PM
leftyjm
Motorcycles For Sale
Apr 2, 2021 02:52 PM
Gordon
Jul 25, 2016 09:25 PM
hotroddarin63
Feb 26, 2011 12:39 PM
Softail Girl
Dec 28, 2008 09:36 AM
