Instrument Cluster Fogging Issue
The bezel is only partially folded over the plastic, it is actually really easy to get a lever in to ease the half fold out ...just enough to get the glass off ...don't try to straighten the metal ...and don't be a thug and just yank the fold up ...many passes around the whole circumference ...softly softly will do it easy enough.
Getting the bezel back on might be a bit tight if you don't lift the fold enough but some feeler gauges will help pop it back on (or its even easier to straighten the fold a touch more once the bevel is off ...but don't go stupid, just enough to get it back on)
To refold the edge, again, do it softly softly ...ease it down over several passes ...and just enough so that it had a good grip ...remember, it wasn't flattened when you started so no need to do that now.
Plus, the fold of the bezel is out of sight in the mount so no one is going to see it unless they take the speedo out again.
Take your time, you'll be fine
Cheers,
M
