2018+ Softail Models Breakout
Instrument Cluster Fogging Issue
Old Aug 22, 2023 | 12:30 PM
  #161
MrLongbeard's Avatar
MrLongbeard
I used a pin vice when drilling mine, greatly reduces the potential for the bit to plough on though the board
Old Aug 22, 2023 | 06:49 PM
  #162
Uncle G.'s Avatar
Uncle G.
This. When I said “drill holes in the back” I didn’t mean grab the power drill and go to town. I think I recommended the pin vise route as you can feel your way. The plastic is very soft and drills easily.
Old May 5, 2024 | 09:03 PM
  #163
MHTR's Avatar
MHTR
Default I think I’m ready to call this a WIN
Just wanted to report that I took on the condensation problem with my speedo this year (’18 FLDE). I did the modifications late Feb and have ridden about 2,000 miles in temps ranging from 45° to 90° (it’s early May now). Now, I haven’t ridden in any 100° hot & humid days, but MY condensation problem was not a seasonal thing. I think I’m ready to call this a WIN.
I’m not going to suggest that anyone do this unless you are prepared to take a chance on ruining your instrument. I drilled the holes on a drill press (where I could control the depth of cut) and used a vacuum cleaner to remove the chips while the holes were being cut. Here are a few pics from the mod:
The layout
Five holes
Old May 6, 2024 | 05:58 AM
  #164
Lammy1000's Avatar
Lammy1000
Good to hear it worked for you. I used a pin drill to create holes in the back of my console 2 years ago and it worked.
Old May 6, 2024 | 07:38 AM
  #165
LaRSin's Avatar
LaRSin
Originally Posted by T^2
That's roughly what I usually experience. About an hour or so ride on a sunny day and the fog cooks off. That's why I've never been that motivated to do something about it.
If I where to attempt drilling holes... I might take a look at this video...
https://www.youtube.com/watch?v=2PE7IbZ7cKE
I'm guessing it might be better to attempt to put a pin sized hole in the side of the speedo's outer case instead of drilling a hole in the bottom. That way if you go a tad too deep you only encounter the outer plastic shell of the inner assembly (vs. the PCB, electronic components etc.). If one's theory is that getting the thing to breath is the answer, then it seems you would only need to break the seal to achieve that. Maybe around this location...
Alternatively, maybe anywhere around the 3 or 4 O'clock position might work equally as well. Or maybe 8 or 9 O'clock.
Of course this all assumes that breathing is the answer. Going by other's post alone, seems like it might be dubious.
Anyway... My 2 cents.
I wonder if you drill into the side of the speedo , looks like there is a safe place there ..
Kenneth Foster
May 31, 2019 07:51 AM
Blazn
Oct 27, 2018 09:36 PM
pcmc2
2014-2024 Touring Models
98
Dec 31, 2017 07:22 AM
ultrazteb
Aug 5, 2011 09:33 PM
Biker_RN48
Feb 11, 2007 11:48 PM
