2018+ Softail Models Breakout
Help with code P0106
Old Nov 5, 2021 | 10:30 PM
NewVagus's Avatar
NewVagus
1st Gear
Default Help with code P0106
Hello, I would greatly appreciate some recommendations on how to resolve my problem with my 2021 Sport Glide. At 1000 miles I had a S&S 475 cam, cam chest kit, air cleaner installed and dyno tuned. After picking up the bike I thought it was running rich but figured it was maybe not tuned properly. After about 40 miles or so the light came on and it's a P0106. I can't find too much information on it other than MAP sensor circuit range. Any ideas of what might be going on? Thank you in advance for everyone's input.
Old Nov 6, 2021 | 12:42 AM
Agoober's Avatar
Agoober
MAP sensor code I think.
You're going to have to figure it out as you've got no warranty.
Maybe reprogram the ECM for that cam , clear codes first. What tuner do you run ?
Old Nov 6, 2021 | 05:38 AM
d_slat's Avatar
d_slat
Take it back to whomever did all of the work and tuning. Chances are, there's something that they need to make right.
Old Nov 6, 2021 | 08:08 AM
Jeremy Belko's Avatar
Jeremy Belko
What tuner?
P0106 is air flow sensor code. It’s possible sensor is bad, but start with cleaning it really good. Scotty Kilmer on YouTube had a bunch of videos about how to clean the MAF sensor on a car. Same principle on your bike
Old Nov 6, 2021 | 08:53 AM
rick601's Avatar
rick601
^^this^^ even if it's so they can suggest something- though hopefully they'll make it right.
Old Nov 6, 2021 | 09:58 AM
NewVagus's Avatar
NewVagus
1st Gear
Thank you. It was dyno tuned and I cleared the code the first time it came on. I run Power Vision.
Old Nov 6, 2021 | 09:59 AM
NewVagus's Avatar
NewVagus
1st Gear
Thank you. That's my plan but I like to get an idea of what's going on before I take it in.
Old Nov 6, 2021 | 10:03 AM
NewVagus's Avatar
NewVagus
1st Gear
Originally Posted by Jeremy Belko
What tuner?
I have Power Vision. The bike has 1100 miles on it now. It's possible that the sensor is bad but it's not my first suspect. Thank you for your help.
luckiestiff
The Dyno Room
Dec 30, 2020 01:21 PM
Jeff1759
Milwaukee Eight (M8)
13
Apr 9, 2019 01:05 PM
Mirracm
Exhaust System Topics
Aug 22, 2015 09:01 PM
kreeess
Jul 26, 2015 10:49 PM
Tee Bagger
Jan 15, 2014 07:35 PM
