2018+ Softail Models Breakout
removing the plastic plugs to install a crash bar 21 FLHC
Old Dec 5, 2022 | 11:47 AM
dmonger's Avatar
dmonger
Default removing the plastic plugs to install a crash bar 21 FLHC
So I am the type that hates riding without a crash bar, call me paranoid or whatever, but I prefer knowing that if something happens, I am not going to destroy my tank and bend the fins on my motor. I see that two plastic caps are slotted in the mounting holes where the bar will go, but how do y'all get them out? I got a screwdriver behind it, but I couldn't pry them out, and I can't find anything in the service manual.
Old Dec 5, 2022 | 11:57 AM
GalvTexGuy's Avatar
GalvTexGuy
I believe they are Christmas tree clips and they are a bear to remove.
Old Dec 5, 2022 | 01:45 PM
702's Avatar
702
Bust the head off them and knock them out with a punch. Use a small punch so you don't bugger up the threads.
Old Dec 5, 2022 | 02:12 PM
Durham man's Avatar
Durham man
Put a slit in it and turn it out, they are threaded. Tape around it so you don’t scratch.
they are a bitch!
Old Dec 5, 2022 | 06:18 PM
John107's Avatar
John107
I initially had the same issue on my 2018 Deluxe when installing crash bars. I started with a flat head screw driver until the slot was widened and deepened, then used a narrow nosed vice grip to unscrew the cap. neat and clean. I don't expect to use the caps again.
Old Dec 6, 2022 | 06:13 AM
Steve Sportster's Avatar
Steve Sportster
I remember what a pain these were to remove on my 2018 Heritage. I traded the 2018 in on a 2022 last month but kept the crash bars. When I remembered these PITA plugs I decided to try something different. I gave them a whack with a punch from the inside and they popped right out. Easy.
Old Dec 6, 2022 | 07:10 AM
bronxbill's Avatar
bronxbill
Exactly what I did, use a wooden dowl and it will not hurt the threads
Old Dec 6, 2022 | 08:44 AM
snake_eyes's Avatar
snake_eyes
This^
Old Dec 6, 2022 | 10:41 AM
BareKnuckle's Avatar
BareKnuckle
Same here, took all of about 2 minutes.
Old Dec 6, 2022 | 11:27 AM
shiftace's Avatar
shiftace
drill a sheet metal or drywall screw into the center of the plastic plug, use pliers to pull it out. We do them all the time at work like that.
heljag
Oct 12, 2021 02:50 AM
Bob_fxdb
Oct 17, 2018 01:53 PM
smokinfromshootin
2014-2024 Touring Models
Jul 2, 2015 06:49 PM
TwoBlue02
May 16, 2013 08:12 AM
ANESTHESIA
Jan 21, 2011 03:45 PM
