2018+ Softail Models Breakout
Neutral
Old Mar 4, 2023 | 08:57 AM
Wmitz's Avatar
Wmitz
With new bikes the clutch can be draggy. A couple of things you can do easily. To run the clutch in, you drop it into first, apply the front brake and slowly let the clutch out and let it slip a little, do that a couple of times, don’t stall the engine, or try starting out in 2nd gear at an intersection/light a couple of times, that’s all it should take. Make a note of where the clutch starts to engage, and your free play, mine had to be adjusted a couple of times under 1k.
Old Mar 5, 2023 | 05:24 PM
IBE's Avatar
IBE
i have no problem finding neutral. but one of my buds wanted to ride my fatboy and he has a 21 roadking. i couldnt wait to see how the roadking drove. i used to have a roadking and miss it very much. first shift i could Not get it past neutral when shifting. then had to really push it hard to get past neutral into 2nd gear. not that way on my fatboy. but not hard to find either.
Old Mar 5, 2023 | 11:06 PM
wztravis's Avatar
wztravis
Applying inward pressure on the shifter 100% solved the neutral issue for my 19 flhc.
Old Mar 6, 2023 | 10:01 PM
Astro Glide's Avatar
Astro Glide
Originally Posted by Husky44
I plan on changing all three fluids at 100-miles anyway. Just never had a bike that neutral was this hard to engage. Oh well time to learn
Do what you want, but HD runs break in oils for a reason, which is why they suggest changing out at around 1000 miles. Don't short change yourself, you might want to wait and let the factory oil in there do it's job, before you change it out.
I found it a lot easier to find neutral after the last service with HD putting in their Heavy gear oil 70w-140 synthetic in the transmission and primary, 2018 Sport Glide with 15k miles.. Maybe this works for you at your 5000 mile service too.
Old Mar 7, 2023 | 07:56 PM
Since 1968's Avatar
Since 1968
Maybe I got lucky or maybe it's the miles. Actually, not that many around 16k. I adjusted the clutch cable a couple of times but what really helped was going through the whole procedure starting with the clutch itself. It is tougher to go down from 2nd, but coming up from 1st it's almost like it's a Suzuki, neutral is there every time whether rolling or stopped.
Old Mar 7, 2023 | 08:42 PM
Husky44's Avatar
Husky44
I plan on adjusting the clutch at the first service (~1K-miles). I'm going to use HD tune-up kit for the first service. On a not related topic any idea what the spark plug gap and torque is?
Can't find any service manuals available online and the dealer says not out yet for a 2023.
I'm a retired mechanic, ex-dirt and street racer since the 70's.
Old Mar 7, 2023 | 11:41 PM
rocketnorton's Avatar
rocketnorton
just curious what "pushin the shifter in" does to make it easier
i could see it on a wore out 4spd sporty
Old Mar 8, 2023 | 12:09 AM
M Oclaf's Avatar
M Oclaf
It just works? I try to let folks know…it’s worked for all 5 Harleys I have owned. I picked it up from at the time an older bike dude. It’s like turning your bars right to get bike off the kickstand. Easy peasy. Slight inward pressure on the lever while pulling up with toe/boot/sandals/whatever. Don’t overthink the tricks offered.
Old Mar 8, 2023 | 01:11 AM
Astro Glide
Gap at .031" to .040". Use a pinch of dielectric grease on the threads of the plugs. Unless you're revving the crap out of the engine or you start putting high rpm horsepower racing cams in the motor that grossly affect the swirling effect of air and fuel that erodes the electrode and eats the gap wider and wider, the gap should remain pretty constant and increase quite slowly.
I gap at .030" and only check plugs if hard to start or I see a lot of the wrong colored carbon exhaust on the inside of my tailpipe after a decent 30 minute freeway run. Fuel injected and a proper tune eliminate a lot of these problems.
Torque should be the same as in 2022. Use factory plugs with a fat electrode, you need that fat spark to ignite a lot of fuel initially to fill that fat 4 inch bore.
Old Mar 8, 2023 | 03:42 PM
Kenelz's Avatar
Kenelz
The spark gap and torque is in your owner's manual also, it's in the Specifications section towards the front. On page 34 of my manual, but mine is a 2021, should be close. .03-.04 gap, and 89-133 inch pounds torque.
My neutral was pretty much non-existant. The dealer re-adjusted the clutch, no help. I adjusted it to both ends of the spec, and in between. I changed out the primary oil to Red Line and that seemed to help. It is getting better, at 14,000 miles, but most times slams into gear if I do find neutral and then go to first. I just start it in gear, the slamming can't be good on the compensator. I think some clutches just take a lot longer to break in that others. I've learned to go with the flow.....
