2018+ Softail Models Breakout
M8 Mono Shock
Old May 6, 2023 | 10:14 AM
natural gasser's Avatar
natural gasser
Default M8 Mono Shock
Anyone know if these shocks can be serviced? Meaning the oil be added or changed?
Old May 6, 2023 | 10:22 AM
stormin08's Avatar
stormin08
i have seen threads where some swap the different types of adjusters...but neve had any comment about adding or swapping fluid
Old May 6, 2023 | 04:30 PM
adm's Avatar
adm
They can be rebuilt, but aren't really user serviceable. You'll need some specialist tools.
Old May 6, 2023 | 05:13 PM
shiftace's Avatar
shiftace
Quality Shock Service on instagram could dial one in for you but yeah, not sure about how DIY they are without some special equipment.
Old May 6, 2023 | 06:18 PM
natural gasser
I'm OK with a pro doing the service. I'll look for one. If anybody has a recommendation, much appreciated.
Old May 9, 2023 | 12:22 AM
Durham man's Avatar
Durham man
56 mm shock on the right . 44 mm on the left. 1/2’ longer in length. Raises ride height 1’
Old May 10, 2023 | 05:04 PM
Camarojones's Avatar
Camarojones
1st Gear
What shock is this?
Tom
Old May 10, 2023 | 06:21 PM
natural gasser
Update on the Lowrider ST shock. The small amount of oil that came out was only from the pre-load reservoir. It still operates the top of the shock to load the spring, or not, the same as the shock on my bike. No oil came out of the shock itself. That reservoir is not serviceable. I should be OK. That top part of the shock is the same for both shocks, and if necessary the spring can be compressed, the top part, hose and reservoir taken off as a unit and replaced with a known good unit.
Old May 10, 2023 | 07:55 PM
Durham man's Avatar
Durham man
Originally Posted by Camarojones
What shock is this?
Tom
just a comparison of the stock 44 mm stock oem shock of my 2020 FXLRS to the taller 56 mm oem shock that I installed .
ADVNTR
2014-2024 Touring Models
20
Jun 15, 2019 01:36 PM
DavidStiebel
Mar 10, 2014 09:49 PM
PostalRoadKing
Jul 10, 2010 11:12 AM
capt_caveman
Jun 29, 2009 08:25 PM
undrdog
Jan 28, 2008 08:17 AM
