2018+ Softail Models Breakout
2018 Lowrider, SAT FOR 4 YEARS
Old May 28, 2023 | 11:17 AM
Stangallmotor's Avatar
Stangallmotor
Default 2018 Lowrider, SAT FOR 4 YEARS
Hey Fellas, Just bought a 2018 Lowride with 366 miles from an older gentleman for 8k.
Bike didn't start when I bought it but I replaced the battery & key FOB battery, added ethanol free gas and the bike started right up.
Bike was stored in garage with fuel stabilizer and very little fuel. I didn't drain fuel yet but will this evening. I looked inside the gas tank as best I could like a flashlight and didn't see any rust.
I plan I changing the oil, Trans fluid, & primary.
Anything else I should do?
I already ordered a new pipe, Bars, grips. Thanks!!!
Old May 28, 2023 | 11:38 AM
ConfuciusSay's Avatar
ConfuciusSay
Check the tire pressure!!!
Old May 28, 2023 | 11:51 AM
nevil's Avatar
nevil
Brake fluid flushing for sure.
Old May 28, 2023 | 01:23 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
Spark Plugs.
Old May 28, 2023 | 05:37 PM
Bricklayer's Avatar
Bricklayer
$8,000? You got a smoking deal on that bike!!
Have the same bike, but had mine painted black.
Old May 28, 2023 | 05:57 PM
Bricklayer's Avatar
Bricklayer
Originally Posted by FranBunnyFFXII
Spark Plugs.
Why new spark plugs? The bike has only 366 miles on it.
Old May 28, 2023 | 08:29 PM
Stangallmotor
Yea 8k, The guy was moving to TX and didnt want to move it. 8k is what the local HD dealer offered because it wouldn't start. It was just the key FOB battery too!
Old May 28, 2023 | 11:40 PM
Astro Glide's Avatar
Astro Glide
I would flush the fuel tank, and the brake fluid/ brake lines. That's it. Continue to run the break in oil until you get 1000 miles on the bike, and then change the 3 holes out. A 20w-50 V twin full synthetic in the engine, and HD Heavy Duty Syn 80w-40 in the primary and gearbox. 34 fl oz in the primary, 30oz in the gear box. The Heavy Duty Syn, as noted by many here, makes it much easier to find neutral.
Old May 29, 2023 | 06:34 AM
pjbuilder's Avatar
pjbuilder
I'd put air in the tires, check the fluids, and ride it. Probably stay local for the first 100 miles or so. Congrats on a great deal. Enjoy it!
Old May 29, 2023 | 07:01 AM
Bricklayer's Avatar
Bricklayer
Believe its 36 oz in the primary and 28 oz in the tranny, at least in my 2020 it is.
And the heavy duty syn is 80w-140.
