2018+ Softail Models Breakout
Pullback risers
Old May 15, 2024 | 02:36 PM
6speeddynaz's Avatar
6speeddynaz
Originally Posted by FXLRyan
also if you need only pullback, theres a few pullback plates out there that are a simple bolt on design
i did not know that.
Old May 16, 2024 | 09:12 AM
Mr.Rabies's Avatar
Mr.Rabies
but they are like $977937373
called a pull back plate
Old May 16, 2024 | 09:15 AM
6speeddynaz
yes I see they ain’t cheap. But whatever, right? Do you guys think I’ll need extensions for doing a plate? Obviously the people at getlowered.com tell me I do, so I can buy from them.
Old May 16, 2024 | 09:45 AM
Mr.Rabies's Avatar
Mr.Rabies
a pull back plate that comes back 2 " and up 1" is well. about 3" of stretch. slap one on your cables and wires will need to accommodate.
what i did when installed a plate and risers, before i did i held the bars exactly where they would be and measured where clutch/brake/wires should be plus 1-2" to be safe.
Old May 18, 2024 | 10:45 AM
CarlosGGodfrog's Avatar
CarlosGGodfrog
Check out ROX.
https://roxspeedfx.com/collections/m...ndlebar-risers
Also, I have seen them on ebay.
Old May 18, 2024 | 12:51 PM
Firedude2's Avatar
Firedude2
I just installed 10” pullback risers from Boosted Brad (DMR). They fit my riding position perfectly. I have always been a 16” ape guy on all my Harleys (currently have them on three of my bikes) but on this bike I really like this setup. I have a set of Drag 5 1/2 pull backs I just pulled off if you want to give them a try.
Old Jul 2, 2024 | 12:14 PM
NZLowrider's Avatar
NZLowrider
I have the Trashing supplies 9.5" pull-back risers along with their flat bar, I have just ordered their 1" riser spacers (which should suit me better I'm 6ft), anyone used them?- https://www.thrashinsupply.com/colle...ser-extensions
Old Jul 3, 2024 | 09:51 AM
berfatboy114's Avatar
berfatboy114
Default Hard to find spacer
Originally Posted by mikec35
You can add 2" spacers to raise the bars up 2", they will come back a little, plus you can loosen the bar clamp and turn the bar back some towards you... Anything more than 2" higher than what you have will require longer cables. I added 2" spacers and it's almost perfect for me.
The local HD parts desk claims no spacer is available for the stock 2023 fatboy.
I found that hard to believe.
Old Jul 5, 2024 | 08:19 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I don't. There's lots of stuff like that which Harley does not carry or offer. Looking at the bling web page Harley has for the 23 fatboy, there are no spacers listed, and only a few risers.
Old Jul 5, 2024 | 10:30 AM
Gorion's Avatar
Gorion
Veteran: Coast Guard
I put 2" LA chopper spacers on my Breakout. work great.
