18' FXLR Upgrade Suggestions Needed
* Arlen Ness Monster Air Sucker kit (on its way to me)
* D&D Low Cat Up-Swept Exhaust
* S&S 475C Cam kit with Oil Pump, Cam Bearing, Tappet sleeve
* Thunder Max Auto Tuner
Questions:
* Are there better setups I can go with?
* D&D exhaust do not have Cats. How does the TM tuner know what to adjust?
* Do I have to tune after stage 1 or can I do it after stage 2?
Appreciate any advice anyone can offer.
Questions:
I think the Cycle Rama 480 MT is an impressive cam.
Their APE 483 also does well.
If you are going with a new cam there are better choices than the SS475.
As for tuners, the TTS Mastertune and the Powervision 3 & 4 are less than half of what the ThunderMax costs. You can get maps for them that will allow you to start and ride the bike, some will be better than others. A dyno tune will be necessary to get the most out of you build. They use the ECM that came with your bike, they just change the tune that's in it. Unless something has changed recently, ThunderMax uses Alpha-N technology, which the automotive industry quit using in the late 1990's & early 2000's. Again, unless something has changed, you lose the knock sensors with the ThunderMax. This is something I find worthwhile, maybe you don't. If you decide to go with the ThunderMax, I would contact Cycle Solutions. They are probably the best tuners for a ThunderMax. They can help you do tuning runs to optimize your performance until you can get to have a dyno tune.
