2018+ Softail Models Breakout
M8 Smell?
Old Nov 12, 2024 | 09:20 PM
  #31
Rounders's Avatar
Rounders
Some gear lubes smell like sulphur.
Old Nov 12, 2024 | 10:58 PM
  #32
Far 3ast's Avatar
Far 3ast
Check your exhaust header and any other hot areas around the engine for something that shouldn't be there. I used to have a BMW F800GS that smelled like a burning garbage pit after a ride. It took a while, but I finally found the culprit -- a piece of plastic from above the exhaust manifold had broken loose and wedged itself right at the exhaust header, and every time I rode that plastic got hot, melted a little, and gave off that smell. I fished the broken plastic out of there and cleaned up the header, and no more smell.
Old Nov 14, 2024 | 04:27 PM
  #33
AgentOrange883's Avatar
AgentOrange883
My 23' Heritage had a horrible smell once parked after a ride as well. It ended up being protective plastic that wasn't fully removed from the mufflers during PDI by the dealer. I had to crawl on the ground and look up at the mufflers to find it - pretty hard to see. The plastic was partially melting, I removed it - smell gone. Hope this is the case for you as well
Old Nov 17, 2024 | 11:37 PM
  #34
BunnoHD's Avatar
BunnoHD
you say it smells like rotten eggs, thats a tell.
lot of trans lubes have a heavy sulfur smell, id be checking transmission filler and top cap see if its leaking
Old Nov 18, 2024 | 03:44 AM
  #35
DeeRoe's Avatar
DeeRoe
Transmission venting has that "rotten egg: smell. Some are worse than others. When I use Formula+, I don't smell it as bad as when I use the HD Gear oil. When I've used Redline Shockproof, I get no stank whatsoever.
At the 1k service, everything is just settling in, and you may not notice as much. After awhile, it becomes a routine smell that you don't need to worry about. All of this was told to me by a HD Master Technician who knows his stuff.......a rarity at a a dealership these days.
darmahman
Nov 14, 2024 01:48 PM
patsfan05488
VRSC Models
Jul 10, 2012 08:53 AM
JokerRides
Exhaust System Topics
Feb 26, 2012 08:55 AM
Sincecrazy
Apr 6, 2009 07:51 AM
xmikex2
Jul 7, 2007 12:20 AM
