2018+ Softail Models Breakout
Help needed: Codes after a Riser install
Old May 11, 2025 | 05:53 PM
BuddyB's Avatar
BuddyB
Default Help needed: Codes after a Riser install
So I installed a Bung King 6" Riser today. Had to disconnect the wires since the Bung King is a one piece riser. So put everything back together. Fired it up to go for a ride. Right away a check engine light. A little surprised. Pulled the main fuse before pulling the plugs then put it back in after project completed. So during the ride noticed the bike seemed like it was in limp mode. Came back home and checked the codes. ECM Y so scrolled through it. P1510c. There were 2 codes. One cleared the other did not. It's PN 00228-01. Went back into the boot where the wires are, which was actually the worst part of the install, and checked the wires. All connected. Although a few are a little tight. I think it's the signal wires. Anyway. Any ideas so I don't have to take it to the dealer.
Old May 11, 2025 | 07:43 PM
GalvTexGuy's Avatar
GalvTexGuy
The code is for throttle by wire coming from the throttle. Double-check your connections again on both sides of the plugs.
Old May 11, 2025 | 08:39 PM
BuddyB's Avatar
BuddyB
Thanks brother. I actually went back out to the garage a few minutes after I posted this and there was a bent pin in the female part of the connector. Straightened it out and presto magic no code. Took the bike out for a ride and it's back in beast mode.
timfresh
Electrical/Lighting/Alarm
Jun 4, 2022 08:40 PM
silverbullitt
Jun 1, 2014 06:15 PM
lonelyrider1966
Sep 18, 2013 07:45 PM
Chips
May 17, 2010 01:07 PM
BFMC
Mar 20, 2005 11:17 PM
