Lhcm
Installed everything new. Very meticulously pulled new wires. No pressure used in pulling. Made sure wires were installed in housings correctly and no wire could be pinched when installed on bars. Replaced all the fuses in the fuse block to make sure one wasn't burnt or broken even though they look OK. I didn't de-pin any connectors. I've checked that all pins are fully locked in connectors. Still no power to LHCM. RHCM works and lights up. LHCM don't light up. No functions on LHCM work. Left signal light comes on and will flash with hazard control from RHCM. What could be causing my problem? I need someone way smarter than me to help!!
Hopefully if you are doing this kind of work you have a DMM & a FSM. Try this:
- with ignition on check for power at the LHCM by measuring between the + & - at the LHCM. Whether or not you have power, wiggle all the wires to see if the voltage fluctuates, if it stays as power then the LHCM is probably bad.
- check continuity of all the wires between the LHCM & BCM with you DMM.
- check to ensure there is no connection between any of the wires to ground.
- If all the above checks out, then I’d replace the LHCM.
Also, with some diligence, you could hook up the RHCM to the LHCM wiring at the LHCM…and see if the RHCM works. If it does work..then your LHCM is definitely bad.
Btw…this is not the first post of things going bad after swapping bars.
Look at the schematic, do you have 12v on the red battery fuse wire pin 1 on connector 24 D? If not you need to trace that wire back and find where it’s open.
The other pages are from a 2016 Electrical Diagnostic Manual , I’m guessing it’s the same procedure for yours. Connector 91 is the data link connector under the left side cove.
