confusion
Old Mar 3, 2018 | 06:02 PM
usmc9550252525's Avatar
usmc9550252525
Stage II
Default confusion
I just installed 14" apes on my 2014 street glide special. ran the wires, and had to replace the green connector because if it was bad. I think I reconnected all the wires correctly and now the bike will start but no throttle response and the engine light is flashing and the abs light is flickering? any help would be great
Old Mar 3, 2018 | 06:22 PM
dawg's Avatar
dawg
You replaced or did away with the green connector? Most cut the green connector out or use the TBW without the connector inline. Retrace your steps as you probably mismatched some wires.
Old Mar 3, 2018 | 09:44 PM
Kermie's Avatar
Kermie
I'm with the Dawg on this one too. I took lots of pictures of the wires before pulling them out of the stock bars. Go thru and trace all the steps again.
Old Mar 4, 2018 | 12:15 PM
usmc9550252525
Stage II
the new green connector end that comes thru the handlebars, the adapator is much larger and doesn't adapt to anything. the pictures I took were not good enough to use to reconnect connectors. is there a place to go and get pictures of the proper connectors and were each go? I didn't buy the extenders i just flipped the wires. any help thankz
MCRSMedic
Feb 17, 2019 03:34 PM
dmarion
Jul 8, 2015 10:05 PM
RodeoHard
Electrical/Lighting/Alarm
11
Mar 19, 2013 03:38 PM
Mark98012
May 1, 2012 01:56 PM
georgiabiker
Mar 19, 2008 06:57 PM
