Need Help With Wiring Problem
Old Feb 23, 2011 | 10:49 PM
medic8499's Avatar
medic8499
Default Need Help With Wiring Problem
I Just installed the Chubby 0577 on my 10 SG. I ran the wires though the bars and now when I press the front brakes my right turn signal comes and goes off if I press the brakes again. It only does it while Im going down the road. Sitting still I cant get it to do it. I checked all the wires again to be sure there wasnt any exposed wires and found nothing. Any Suggestions on what might be causing this?
Old Feb 23, 2011 | 10:56 PM
robertg's Avatar
robertg
My first guess is you have a couple of wires crossed. What else could it be?
Old Feb 23, 2011 | 11:07 PM
BenRK05's Avatar
BenRK05
I might be just a wire strand or two. It only comes on because the power output is higher when your underway. It stops working when you put on the breaks because you slow down the rpm's when you put on the breaks. I would check the wire that controls your break light.
Old Feb 24, 2011 | 11:08 AM
medic8499's Avatar
medic8499
Thanks Alot... I will check them out
Old Feb 24, 2011 | 11:42 AM
my67pnycar's Avatar
my67pnycar
I agree, sounds like is crossed or something is making contact when you pull the front brake. Did you take the switch housings apart when you switched? If you did, something inside the switch housing is making contact when it shouldnt, worth a look. Hope this helps.
Old Feb 24, 2011 | 01:07 PM
medic8499's Avatar
medic8499
Yea, I took the housing apart to install on the new bars. I will take a looking in the housing to be sure nothing is touching. It only does it when Im going down the road and put the brakes on. Sitting still I have applied the brakes and shaken wires and it works fine.. Thanks for the info, I will keep trouble shooting.
Old Feb 24, 2011 | 01:19 PM
my67pnycar's Avatar
my67pnycar
Hopefully you will find that little gremlin,lol. Good luck man and stay safe.
viperpit07
Nov 26, 2019 05:04 PM
usraptor
Electrical/Lighting/Alarm
Mar 6, 2014 09:05 PM
artizinn
Sep 9, 2011 03:58 PM
Doc Danielz
Apr 9, 2011 09:47 PM
uscanuck
Feb 21, 2011 10:40 PM
