2018+ Softail Models Breakout
Risers on a New Fatboy
Old Sep 13, 2025 | 03:23 PM
Kickers1999's Avatar
Kickers1999
2nd Gear
Default Risers on a New Fatboy
Just bought a 2025 Fatboy, does anyone know if I can put on up to a 2" pull back riser without changing cables and the brake line? Thanks in advance.
Old Sep 13, 2025 | 03:31 PM
imoo6170's Avatar
imoo6170
@Kickers1999 I have moved this thread from the Welcome section to the 2018+ Softail Models section as you will get better responses to your question in this section. The Welcome section is more for introducing yourself & letting other forum members know what Harley Davidson you own, not asking technical related questions.
Old Sep 13, 2025 | 04:32 PM
470004's Avatar
470004
Welcome to the forum.
Old Sep 13, 2025 | 04:41 PM
Jackie Paper's Avatar
Jackie Paper
Welcome to the HDFORUM.. Can't answer your question but bumping you to the top..
Old Sep 13, 2025 | 07:11 PM
Kenelz's Avatar
Kenelz
I put a 4 1/2" pullback riser on my '21 FB. The stock clutch cable was plenty long, the brake cable was tight, but removing the P clamp gave enough room. I ended up installing a +2 brake hose so I could put the clamp back on.
If your just doing 2", you are definitely good.
Old Sep 14, 2025 | 10:17 AM
tmac00333's Avatar
tmac00333
2 inches wont be a problem
Old Sep 14, 2025 | 06:40 PM
chunks's Avatar
chunks
The stock risers on a 2025 fat boy are already 2 1/2 inches.
I don't know if you're gonna get any of that are the same height with any pullback
Old Sep 15, 2025 | 03:08 AM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
Stock Riser height on the FLFBS is 2 3/4inch IIRC. 1.25inch clamp area thickness for stock Fat Boy FLFBS handlebars.
Kickers1999
Sep 15, 2025 09:06 AM
greybeard122
Mar 21, 2022 06:24 AM
cmosentine
Jul 14, 2013 10:08 PM
dansax
Apr 16, 2010 08:10 AM
RayrayFatty
Jun 26, 2008 10:05 PM
