2018+ Softail Models Breakout
Time to upgrade the front suspension?
Old Feb 7, 2026 | 05:01 PM
morooster's Avatar
morooster
Default Time to upgrade the front suspension?
When I'm going at around 80-85 and the freeway gets those undulations, my bike will feel like its going to rock itself into a wobble. Normally I just slow down and get out of the fast lane, but its a pretty big buzzkill. I have a 13.5" shock in the rear so I'm curious if an upgrade like let's say GP cartridges will handle those better. It's a pretty big investment if I let them handle the labor, so I had to consult the wise posters of hdforums. Do Touring bikes handle road irregularities better?
Old Feb 7, 2026 | 05:39 PM
Biggzed's Avatar
Biggzed
Is this a new issue, or been around since day 1? If it's new, I would check over the bike over front to rear. Engine mounts, suspension, bushings, tires, fall away adjustment etc.
Zach
Old Feb 7, 2026 | 08:36 PM
drbf's Avatar
drbf
I agree with Biggzed, i do not have any wobble at 80-100 miles/hr. Let us know how you resolve the problem?
Old Feb 7, 2026 | 08:48 PM
chopper_man's Avatar
chopper_man
North of that very frequently, never an issue. Perhaps the aerodynamics of your scoot.
Old Feb 7, 2026 | 10:54 PM
morooster's Avatar
morooster
Hm.. OK, Looks like I will need to check some things. So everyone has a rock solid ride but me, that's concerning
Old Feb 8, 2026 | 12:31 AM
Durham man's Avatar
Durham man
Low rider s and st inverted forks have the same internal’s as regular forks. Don’t know if Harley improved the newer ones. I went with Olin’s . That said never had high speed problems with the stock fork’s. I also run a 13.5 rear shock and my tubes are down in the tree’s to raise the front and level the bike. Great setup.
Old Feb 8, 2026 | 12:33 AM
Durham man's Avatar
Durham man
Old Feb 8, 2026 | 05:43 AM
GalvTexGuy's Avatar
GalvTexGuy
So, did it always handle like you described or did it start after installing the shock, the handle bars, the windshield or some other change you made to the bike?
Old Feb 8, 2026 | 02:45 PM
morooster's Avatar
morooster
I am pretty sure it just got slowly worse over time. I did change out the bars and risers and triple tree. Could be some bolts that need to be retorqued
Old Feb 8, 2026 | 03:20 PM
GalvTexGuy's Avatar
GalvTexGuy
Triple tree? Did you increase the rake angle?
