2018+ Softail Models Breakout
2018 Deluxe with a stiff neck.
Old Mar 28, 2026 | 03:04 PM
Julie Peraza's Avatar
Julie Peraza
4th Gear
Exclamation 2018 Deluxe with a stiff neck.
So I have a 2018 Deluxe with around 25K miles and after sitting for a while it acted like the fork lock was engaged, even though it wasn't. FInally "worked" it out and now it seems to be "catching" while turning. Like when power steering on a car starts to go out. Read somewhere that there is a pin in there that can cause problems when it is catching on things, but honestly I might as well have been reading Greek. So looking for possible diag before I head to the dealer so they can't #^$^ my eyeballs out!
Thinking a neck bearing or faulty fork lock mechanism, but could there be something else, maybe something more D-I-Y-ish?
Thank you!
Old Mar 28, 2026 | 03:27 PM
MesquiteFLD's Avatar
MesquiteFLD
Did you lubricate the lock mechanism?
Old Mar 28, 2026 | 04:51 PM
Julie Peraza
4th Gear
I did, though not sure how well. I will try that again.
Old Mar 29, 2026 | 01:31 PM
DikTish's Avatar
DikTish
Did or do you power wash your bike in the neck area?
Old Mar 29, 2026 | 01:45 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You need to pull the ignition switch lock and inspect.
Old Apr 2, 2026 | 01:02 AM
justcruising's Avatar
justcruising
When turning the handlebars the upper half of the clutch cable slides through an insulated P clamp mounted on the LHS of the Nacelle. Check this is still sliding freely with steering movement, without undue wear or jamming 🤞🍻
Mercuryman
General Topics/Tech Tips
Mar 23, 2025 07:27 PM
lloyd123
May 13, 2014 11:53 AM
2807
Jul 2, 2013 10:54 PM
amervtwin
Oct 20, 2009 09:05 PM
amervtwin
Oct 19, 2009 11:34 AM
