2024+ Center-Cooled Touring Models 2023.5+ CVO and 2024+ Road Glide/Street Glide/Street Glide Ultra Center-Cooled Gen 2 M8 Touring models
USB C port won't stream music
Old Sep 10, 2024 | 08:36 AM
Trshot's Avatar
Trshot
Stage III
Default USB C port won't stream music
Hello,
2024 Street Glide, when i connect my iPhone 15 pro max to the USB C connector it only charges the phone, i can't stream music from any apps. When connected the connection icon stays grayed out as well. I've used several cords including an Apple cord. Any ideas/help would be greatly appreciated.
Old Sep 11, 2024 | 04:50 AM
Slingshot383's Avatar
Slingshot383
Is there something in the bikes software system that needs to be switched on?
Old Sep 11, 2024 | 06:31 AM
Nutty's Avatar
Nutty
Originally Posted by Trshot
Hello,
CarPlay won’t enable without a dongle. Tim’s Stereo Systems dongle fixes it.
Old Sep 11, 2024 | 07:19 AM
Trshot's Avatar
Trshot
Stage III
This isn’t a CarPlay question
Old Sep 11, 2024 | 07:31 AM
Ducman82's Avatar
Ducman82
do you have a headset synced? if not , it should be saying a message that you need a headset to enable car play (rider). there is a dongle , as mentioned, you can get, or make one. there are a few threads on that. if you go to device manager, click on the phone and try and connect carplay, what does it say?
Old Sep 11, 2024 | 09:49 AM
jake24lt's Avatar
jake24lt
You should be able to stream music from an app, via Bluetooth, without a headset. However carplay, needs the headset connected to work.
Old Sep 11, 2024 | 01:38 PM
Pokey151's Avatar
Pokey151
So I went out and tried to get my phone to stream through the usb port. It will not. I do use blue tooth and stream all my music with different platforms (XM, Itunes, Spotify, Youtube music...) Works fine with Car play or just blue tooth. I also have a flash drive full of mp3's plugged into the usb-c cord and play music from there too.
Old Sep 11, 2024 | 05:49 PM
Nutty's Avatar
Nutty
OK, my bad. I assumed he meant the “C” icon wasn’t lit. He must’ve meant the BT or USB icons.
Old Sep 11, 2024 | 07:19 PM
JAKE 2544's Avatar
JAKE 2544
Yup my 23 CVO is the same, if I plug in with an Apple cord it only charges, Bluetooth works fine. Every once in a while it will charge and play but most times it won’t even after updating.
Old Oct 18, 2024 | 11:55 AM
sprnt96's Avatar
sprnt96
Is there any way to have a shuffle option when using a flash drive like on the older Harleys?
