2024+ Center-Cooled Touring Models 2023.5+ CVO and 2024+ Road Glide/Street Glide/Street Glide Ultra Center-Cooled Gen 2 M8 Touring models
New riser bushings
Old Mar 17, 2025 | 10:01 AM
klammer76's Avatar
klammer76
Default New riser bushings
I'm going to be installing the new chrome lower sliders on my 2024 Road Glide soon. While I have the front end off, I'm thinking of installing a better set of riser bushings. Mine are fine so far (stock bars and risers) but have noticed a bit more movement recently.
For those that have upgraded the bushings, suggestions on which ones to use and your opinion of them. I see that Harley does have a set of polyurethane bushings?
Thanks
Old Mar 18, 2025 | 04:21 AM
Neanderthaler's Avatar
Neanderthaler
I just used the HD ones and they appear to be the same as the Alloy Art GoodenTite.
Old Mar 18, 2025 | 06:21 AM
NEWROADSTER's Avatar
NEWROADSTER
I used the HD as well. I think it was a large improvement over stock and I run the stock bars and risers.
Old Mar 18, 2025 | 08:31 AM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Arlen Ness are pretty good too
Old Mar 20, 2025 | 06:58 AM
FLSTF's Avatar
FLSTF
I used the HD ones also when I switched bars and risers. One tip, put some oil or some type of lube on them before you try to put them in the upper fork clamp. Mine were very tight. Hope that helps.
Old Mar 20, 2025 | 10:20 PM
klammer76's Avatar
klammer76
Thanks for the replies. Going to go with the HD ones. Anyone notice more vibration?
Old Mar 21, 2025 | 05:21 AM
NEWROADSTER
I actually had less vibration.
Old Mar 21, 2025 | 07:23 AM
dontdropit's Avatar
dontdropit
I'm not familiar with the new batwing models but on the Rushmore bikes when replacing riser bushings you sometimes need grind away a little of the fairing to get clearance for 1.25 bars. Doesn't seem to be consistent with all bikes and all 1.25 bars but some have reported having to do this with me being one of them.
jake.mason.2
Milwaukee Eight (M8)
Oct 8, 2018 06:41 PM
Khloesdad
Aug 21, 2018 04:11 PM
Freak Show
Sep 30, 2015 01:57 PM
bob_lamarre
Jun 28, 2013 08:15 PM
waterman7474
Apr 23, 2008 05:49 PM
