2024+ Center-Cooled Touring Models 2023.5+ CVO and 2024+ Road Glide/Street Glide/Street Glide Ultra Center-Cooled Gen 2 M8 Touring models
Homelink install - 2025 FLHXU
Old Apr 23, 2025 | 08:12 PM
mcouture's Avatar
mcouture
Default Homelink install - 2025 FLHXU
Just physically installed the HomeLink module and turned bike on and now there is a check engine light on. Is this due to the fact that the bike needs to be programmed to turn on the HomeLink module?
The code is B213155. I reset the code and it didn't come back so something transient....?
Old Apr 24, 2025 | 07:58 AM
tomato's Avatar
tomato
I installed mine a few weeks ago and did not get a CEL...
Old Apr 24, 2025 | 08:05 AM
Ducman82's Avatar
Ducman82
i installed mine and no CEL. maybe something got wiggled around?
Old Apr 24, 2025 | 09:00 AM
lowbar's Avatar
lowbar
I worry about a lot of crap, but I wouldn't let that worry me unless it comes back. I don't think it has anything to do with a need to program the Homelink. I checked the code list, and I don't see that particular code (my list is from 2024) but that range appears to be related to the headlamp. If anything, I would check that connection.
B213111 High Beam Output - Short to Ground
B213115 High Beam Output - Short to Voltage/Open
B213119 High Beam Output - Circuit Current above Threshold
B213609 Low Beam Output - Component Failure
B213611 Low Beam Output - Short to Ground
B213615 Low Beam Output - Short to Voltage/Open
B213619 Low Beam Output - Circuit Current above Threshold
Old Apr 24, 2025 | 09:27 AM
rideonva's Avatar
rideonva
Closest error code I could find is B213111 and B213119 which related to head light. As I understand on the Street Glide you have to disconnect head light when removing fairing ? I'd double check that it's properly connected.
Oh and while you there make sure to take a picture of your module - you'd need that number to be programmed into BCM. It's not just the "checkbox", S/N also has to go in there.
Your dealer has to do that part.
Old Apr 24, 2025 | 12:03 PM
dbarbee's Avatar
dbarbee
Just a thought, did you happen to turn the ignition switch on for anything while the fairing was off and the headlight was disconnected?
Old Apr 24, 2025 | 06:15 PM
mcouture's Avatar
mcouture
Ahhh yes I did. Was doing some other things to the bike so I did turn the ignition on. I bet that was it!
Old Apr 26, 2025 | 08:52 PM
dbarbee's Avatar
dbarbee
It happened to me almost every time I’d have the fairing off on my previous Ultra-Limited.
Old Aug 10, 2025 | 04:43 PM
Darcman's Avatar
Darcman
Stage III
Mine has the homelink icon on my screen but it is greyed out and I can't select it to program it to a door. Does anyone know what I need to do to fix it? Was it never installed and I need to buy the module? I looked under both side covers and the seat and didn't find it but it sounds like it might be in the fairing?
Old Aug 10, 2025 | 04:52 PM
Ducman82's Avatar
Ducman82
Yes you need the module , behind the fairing. The bracket for it and have the dealer flash it
