Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
Softail Air Suspension ?
Old Feb 26, 2012 | 09:36 PM
tunaman's Avatar
tunaman
Here's how cool JD is and how great his customer service is: I decided to relocate my switches from the horn mount to the console while I have my bike apart, and in the process of removing the switches and soldering them to a connector harness I found that one of the momentary switches wasn't working. I called JD to see if I could get a replacement switch, and he told me to hang for a second. He had a harness set up for that purpose from a couple of years ago and remembered seeing it "just the other day". He found it, and by end of the day it was on its way to me.
JD is a class individual with a top shelf product, and as I've said time and again that is the absolute best mod I've done. I thank him every time I hop on my bike as it just makes it that much more enjoyable to ride, regardless of the type of road or load.
Roger
Old Feb 26, 2012 | 09:47 PM
harleyheaven's Avatar
harleyheaven
Originally Posted by FadeToBlack03NT
Sweet, that's all I needed to know. I love slammed, but I liked the 400 dollar price of 422's. Go big or go home, Shotgun here I come.
Make sure you contact JD and tell him you're a forum member. Also talk with him about the system and make sure all your questions are answered. You'll learn alot and meet a super guy.
Originally Posted by Benway
How's the belt tension when you're all the way slammed?
The tension does vary a little. I lowered my bike to where I ride most of the time and adjusted my belt at that height. It will loosen up a little all the way up and all the way down.
Old Feb 26, 2012 | 09:48 PM
97HeritageSpringer's Avatar
97HeritageSpringer
So, are you guys saying there is no air bag/shock that can be set-up with a manual fill? I am interested in an adjustable set-up, but I do not want switches on the bars and I really don't need a compressor. My bike is lowered, and I ride solo 99% of the time. Once or twice a year, my wife rides with me, and its really too low with both of us on it (the pipes drag on sharp turns, etc). Is there anything like that out there?
Old Feb 26, 2012 | 10:02 PM
Kowan's Avatar
Kowan
JD originally would mount or suggest you mount the switches on the side of the speedo dash.
He now sends a switch mount that uses the horn mounting position.
The picture isn't in focus, but you can see the switches above the coil on my bike.
Some mount them below or on the side of the normally mounted Softail Coil cover near the oil tank.
Old Feb 26, 2012 | 10:27 PM
FadeToBlack03NT's Avatar
FadeToBlack03NT
That would be sick, and probably a lot cheaper. That would be ideal for me as well, but I don't think any of the current bag/shock systems are set up to work this way.
Old Feb 26, 2012 | 10:28 PM
tunaman's Avatar
tunaman
I did a search and can't seem to find any plain air shocks for softails like the old air shocks we used to put on our cars.
You'd be surprised how much you use it if you had one - being able to adjust the height is cool, especially if you want to slam it for show and then raise it for ridability on the twisties. However, the even more useful feature is being able to adjust the damping on the fly - going from a smooth straight road to a bumpy, uneven slab it is awesome to be able to go from Caddy smooth to firmed up just right to be able to even out the ride with just the flick of a switch.
Roger
Old Feb 27, 2012 | 01:16 AM
akmorris81's Avatar
akmorris81
The progressive air tail might be what your looking for. They sell just the air shocks, if you want a comPressor kit for adjusting on the fly it's sold as an option... So my thinking is that they would have a manual set up w/o the compressor kit... Maybe look into that
Old Feb 27, 2012 | 03:44 AM
2008crossbones's Avatar
2008crossbones
i want a shotgun shock soo bad,, but 1500 is a huge pill to swallow for some air shocks on a motorcycle.... as said above,, you should look into the progressive air shock,,, if thats all you want,,,
remember,,we all want the best, but most can't afford it guys,
i could drop $10k worth of upgrade on my bike in 1 hour worth of ordering parts. but reality is, I can't afford to pay to register and insure it right now...,, I'm grateful to still have my harley after these crappy financial times....
Old Feb 28, 2012 | 08:56 PM
thaghost's Avatar
thaghost
I just received my shotgun shock today. Putting it on this weekend. IMO, from all the reviews it's the best route to go.
Old Feb 28, 2012 | 10:10 PM
NC D'LUXE's Avatar
NC D'LUXE
You won't be disappointed at all! Just logged a few miles for the first time on mine tonight, slammed, and I was grinning from ear to ear! If you run into anything and have a question, shoot me a PM and I'll send you my number in case you can't get a hold of JD during the weekend. But it's pretty straightforward. If you are near time for a tranny fluid change you may want to consider it while you have the shocks out.
