Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
Oil leaking from Air Fittings
Old Sep 26, 2013 | 05:48 PM
Bigdaddy_60's Avatar
Bigdaddy_60
2nd Gear
Default Oil leaking from Air Fittings
I have an 01 RK and when I disconnect my HD hand pump from the front air fitting on the right rear fender strut I get a shot of oil, leaking out.
My buddy has a 99 E glide and has the same issue only on the fitting for the rear, only on his the oil actualy streams out.
I cant imagine this is good, oil in the ail lines. Anyone know What's up.
Bigdaddy
Old Sep 27, 2013 | 07:54 AM
Bodean46's Avatar
Bodean46
Shocks are air over oil. My 01 does this as well. Just recently changed oil in mine from factory 5 wt to 10 wt. When I emptied them, the right shock was empty and left had about 5 oz's, which hold 10.2 oz's per shock. It now rides like a Cadillac with both of us on it. Everytime you add or subtract air, it loses a little oil, eventually using all of it on these earlier bikes. I used to check mine every time the wife rode behind me, or packed, on a trip. Now have it set so it is good with both of us and our gear and leave it alone.
ron1026
May 5, 2016 06:09 AM
GEARMASHER
Jun 1, 2015 09:45 PM
trout31
May 30, 2012 08:58 PM
myotherworld
Mar 16, 2012 09:03 PM
FL-kruzen
Nov 17, 2011 08:10 PM
