Keeping battery charged when using high end amp and speakers in accessory mode.
Old Sep 23, 2014 | 03:10 PM
Big Blue Hog's Avatar
Big Blue Hog
Default Keeping battery charged when using high end amp and speakers in accessory mode.
Is there a set up in which, while engine is not running, but you want to listen to the radio and not kill the battery. I have arc amp/6 speaker focal set up and been told 2 songs maybe 3 songs at high volume, then the battery would die.
I am thinking the fix is some set up with a power supply converter, plugged into wall socket 120V AC to your 12 V DC current on the motorcycle.
thanks
Old Sep 23, 2014 | 03:17 PM
Gannicus's Avatar
Gannicus
thanks
Obviously it depends on the shape of the battery but I can listen to my tunes in accessory mode for a least 30 minutes on high volume with out a problem. and I've always had two amps.
Old Sep 23, 2014 | 03:57 PM
AAWAV's Avatar
AAWAV
I got cheapo battery tender hooked up... but then again I took care of my audio in the garage so I usually do not play music on the bike while in the man cave (Denon amp, 4 speakers, bluetooth, an old Dell P4 computer with monitor for research and a 32 inch flatscreen for games on Sunday)
only missing a fridge (kegerator sits in the BBQ area in the BY...)
Old Sep 23, 2014 | 08:58 PM
tdgriff's Avatar
tdgriff
thanks
I plug mine into battery tender and I can play for hours. but I have a new battery . Hope this helps
Old Sep 23, 2014 | 11:14 PM
GLACIERPEARL's Avatar
GLACIERPEARL
I can get at least a half hour out of mine, and I always have it on the tender when not rolling........I am a FIRM believer of the battery tender adding years of life to the battery, cuz I sure am hard on mine !!!
Old Sep 23, 2014 | 11:18 PM
GLACIERPEARL
............. and been told 2 songs maybe 3 songs at high volume, then the battery would die.
Told by whom ??? The battery killer of a non-running bike playing audio, is BASS.....If you have hard hitting, Rap/ Hip-Hop playing, you won't get past a half hour......
If you have a different genre, you'll go longer !!
Old Sep 24, 2014 | 11:47 AM
tdgriff's Avatar
tdgriff
Good advice I keep mine plugged in all the time as well . My last battery lasted 6 years not bad .
Old Sep 24, 2014 | 03:45 PM
Big Blue Hog
thanks for your input. looks like battery tender is easy way to go for at least the 30 minutes.
No U Glider
2014-2024 Touring Models
11
Dec 6, 2016 09:45 PM
1sweetglide08
Audio Systems
Mar 27, 2013 03:35 PM
jeff.georgalas
Aug 26, 2010 07:09 PM
jackinthebox
Jun 9, 2009 09:48 PM
NitroBerserker
Sep 22, 2008 05:24 PM
