Any thoughts on the Rockford Fosgate R1-hd4-9813 setup?
Old Oct 14, 2014 | 08:07 PM
dibe's Avatar
dibe
Default Any thoughts on the Rockford Fosgate R1-hd4-9813 setup?
I have seen this on Amazon for around 310-320. The Rockford Fosgate R1-hd4-9813 setup comes with a 160 watt 4 channel amp and 4 5.25 inch speakers.
I was wondering if anyone had any experience with this setup or could recommend a different setup for right around the $300 price point.
It would be going into a 2008 Ultra Classic.
Old Oct 14, 2014 | 09:06 PM
Gannicus's Avatar
Gannicus
Here you go:
Amp: Soundstream 520.D or Power Acoustik RZ4.2000D - $110.00
Speakers: Infinity 62.11i (2) sets - 220.00
Adaptor Rings: 20 -40 Bucks.
Total - $370.00 Best bang for the buck.
The additional 70 -100 bucks you spend over budget will make a day and night difference in your system.
Old Oct 15, 2014 | 06:04 AM
AAWAV's Avatar
AAWAV
Originally Posted by Gannicus
Here you go:
PLUS one... add 10 awg PowerLine to it and you are better off than the rf setup.
Old Oct 15, 2014 | 06:32 AM
chadbob's Avatar
chadbob
If the extra $70 is a deal breaker only replace the front speakers for now, and replace the rears when you can.
If your life is anything like mine, the passenger is the one who'd be mad at spending the extra $$$, but she may insist after suffering with the stock rears.
Old Oct 15, 2014 | 06:59 AM
dibe's Avatar
dibe
Thanks for the info guys. Having 6.5 speakers sounds much more appealing than 5.25's.
Old Oct 15, 2014 | 10:22 AM
Gannicus's Avatar
Gannicus
Originally Posted by chadbob
if the extra $70 is a deal breaker only replace the front speakers for now, and replace the rears when you can.
+1 lmao!!
Old Oct 17, 2014 | 08:11 PM
dibe's Avatar
dibe
After doing some more research, it looks like there is a good chance I would lose my FM signal if I mounted the Sound Stream amp in the fairing. I do want to keep the amp in the fairing so I am not sure if that amp would be the best.
What are your thoughts on the RF PBR300x4 amp with the Kappa speakers?
Old Oct 17, 2014 | 08:17 PM
UltraNutZ's Avatar
UltraNutZ
Can't use that amp with those speakers. Check out Alpine MRV-F300
Old Oct 17, 2014 | 08:54 PM
dibe's Avatar
dibe
I just saw that it was a 4 ohm amp :'(
I'll have to check out that amp. Any idea if the Alpine amp would interfere with the FM reception? Thanks.
Would it be worth it/that noticeable if I used the PBR 300x2 for the front speakers and replaced the rear speakers with Kappa's while letting the stock head unit power the rear speakers?
Old Oct 18, 2014 | 04:30 PM
dibe's Avatar
dibe
After a lot of hemming and hawing and going back and forth, I think I will go with the sound stream amp. If I run into any FM issues I will return the amp and opt for the PBR300x2. I would probably add a second PBR down the road then at some point.
A couple of questions about the SS stream though. Would I need to relocate my CB module with the SS as it looks like I would have to do with the PBR or could I just make a little filler piece to give the SS amp an even surface to mount to?
Also, anyone know if the SS amp would fit to something like this http://hawg-wired.com/product_info.p...th/2/pPath/199 and if so, any idea how the FM would be effected with the different mounting location?
Thanks
