Audio System FAQ's
Old May 9, 2015 | 08:36 AM
  #31
UltraNutZ's Avatar
UltraNutZ
a little late to the party but good info Little Mike..
Old May 10, 2015 | 12:10 AM
  #32
Racin929's Avatar
Racin929
Ditto!
Old Jun 17, 2015 | 01:12 PM
  #33
blueangel73's Avatar
blueangel73
I want to verify that what i read in the first post and what I am doing are correct.
I have an after market head unit (I have on hand from a car I used to own) that I am installing into an aftermarket batwing (just got new, has four holes for speakers, two per side) with four used stock HD 5.25" speakers (I know there not good, but they were free and work for starts). The speakers are 2ohms input and the head unit is 4ohms output, If I run two speakers in series on each side then they would equal the 4ohm output from the radio, correct?
Old Jun 17, 2015 | 01:20 PM
  #34
UltraNutZ's Avatar
UltraNutZ
You got it bud.
Old Oct 19, 2015 | 03:19 PM
  #35
Scooter869's Avatar
Scooter869
Stage I
Default Need help with 2014 street glide amp installed
Have 2014 and looking to put a amp in the bike do they make a wire harness to plug and play don't want to cut and splice wires I have Rockford fosgate amp I need the info I can get
Old Oct 26, 2015 | 10:02 AM
  #36
SG-Chris's Avatar
SG-Chris
2nd Gear
Default AMP Connections
I have this AMP that was apparently on my bike when I bought it used and not connected. anyone know how to correctly wire it up. I have not seen one before with the input as "+" only. Also not 100% sure what the "com" port is for...
Any help would be greatly appreciated!!
Also if anyone knows how to get in touch with the guys at Street Star Designs that would be helpful too.
Thanks!
Attached Thumbnails Audio System FAQ's-connections.jpg   Audio System FAQ's-overall.jpg
Old Oct 26, 2015 | 01:53 PM
  #37
UltraNutZ's Avatar
UltraNutZ
Chris. I would venture to say the reason it wasn't hooked up is because it utilizes what's called a floating ground (com - common ground) between left and right inputs and the HD system does not work like that. It's separate + and - for each speaker and they're isolated from each other.
So in other words;
left + from radio to amp input LT+
right + from radio to amp input RT+
then either left or right - from radio to amp input COM
problem is, no head unit that puts out more than 2 or 3 watts per channel is going to use a common ground anymore. They did away with that years ago when power output of head units started climbing.
My suggestion is toss it and get you something you know will work before you wind up destroying your head unit.
On the cheap, you can grab something like
this this
and it will work perfectly fine for you and sounds pretty decent too. I've used them a few times.
Old Oct 26, 2015 | 06:14 PM
  #38
SG-Chris's Avatar
SG-Chris
2nd Gear
So in other words;
On the cheap, you can grab something like this and it will work perfectly fine for you and sounds pretty decent too. I've used them a few times.
Thanks for the advice. My intent was a new amp anyhow. Just thought maybe I was getting lucky when I pulled off the fairing!
Old Apr 11, 2016 | 09:21 PM
  #39
jmroadglide's Avatar
jmroadglide
Ok not sure if I post this here so if I need to move it et me know riding a 12 FLTRU with stock head unit and boom amp with boom speakers on the fairing and tour pack. Looking to upgrade fairing and tourpack and possibly better amp and HU. Budget is around 1K and I'm planning on doing the work myself, should like to retain handle bar controls and my goal is to do this once only. I am not DIW super savvy and would like to not have to splice wires but can follow instructions so I'll take all the suggestions I can get
Old Apr 12, 2016 | 05:53 AM
  #40
UltraNutZ's Avatar
UltraNutZ
Since you've already invested in the boom setup, I would start with the speakers first. Replace those boom audio speakers with something of better quality in a 2 ohm version to match that amp. Wrap the fairing speakers with polyfil, line the rear pods with polyfile, and see how you like it. If you think you need more then go for the amp replacement at that point. The speakers will have been already upgraded so you won't have to replace those.
My suggestion for front and rear speakers is the Infinity Kappa 62.11i.
Amazon.com: Infinity Kappa 62.11I 150W 6.5-Inch 2-Way Kappa Series Coaxial Speakers: Car Electronics Amazon.com: Infinity Kappa 62.11I 150W 6.5-Inch 2-Way Kappa Series Coaxial Speakers: Car Electronics
You will need a set of v-twin adapter rings for the rear pods - http://www.vtwinaudio.com/store/prod...r-adapter-kit/
You will need a set of speaker adapter rings for the fairing as well.
http://www.vtwinaudio.com/store/prod...apter-rings-2/
